S2R1k Brisk Flame Thrower
Started by CookieMonster, May 04, 2019, 05:01:02 PM
CookieMonster
So I had NGK that I didn't really have a problem with. But I thought, why not just throw in a fresh set of brand new plugs. I don't know when they were last looked at with 25k miles on the clock.
So I purchased some Brisk plugs (which I purchased in the past and installed in my R1 with no issues), installed them and now...it became a flame thrower. Currently waiting for the bike to cool down a bit to install the old ones back. The Brisk plugs made the bike a bit rough while riding. Granted that the trim needs adjustment but NGK didn't make the bike this rough.
I'm gonna wait for the Magnecor ignition wires I order to reinstall the Brisk plugs back on and see how that turns out.
"Friend don't let friends ride stock"
-S2R1k 992 DESMO LIFE
Yowsa. Time for a back to back plug test.
I doubt the Magnacore wires will do anything better.  They are an upgrade on the cars, mostly Japanese and American cars that come from the factory with carbon core wires.  You have solid core wires on the bike from the factory.
Get yourself a set of new NGKs and [Dolph]
CookieMonster
Well, I reinstalled my old NGKs and it was significantly a smoother idle. No pop or flame throwing. I am expecting the usual little bit of gurgle and small pop every now and then when I got off the throttle. But without ridding it, it sounds much better.
Extremely disappointing considering that I have very similar plugs on my R1 with no issues.
And I'd hate to think that I wasted money on the wires howie. One of the reasons I thought I get an “upgrade” on both the wires and plugs was because I get somewhat hot exhaust from the bottom can and cool air on the top can.
But if I indeed waste money on the wires, I just may return them OR keep for future repair. They haven't got here yet so I got time to think of what I'll do with them.
If they're red, it's an upgrade  ;D
That's what I did - very very long life behind the old ones. Maybe they were cracking and maybe the metal was destroyed. Red red red  8)
CookieMonster
Quote from: stopintime on May 05, 2019, 12:35:17 PM
Nooo...ðŸ˜"
They're blue.
Just to qualify what I said, no issue with Magnecore, they make a quality product.  Unless a resistor went bad or there is an insulation issue they would not be a fix for your Brisk Flame Thrower.
Pipe outers look stock. Any mods to pipes, ECU or airbox?
Twin plug heads with super revenge death berserker, multi point, large flame kernel plugs are clearly too much of a good thing. ;D
Consider an ECU remap if your tune is on the EPAish lean side. Ethanol in fuel leans things out a little more too, so your stock tune could be marginal and a bit fragile in the face of introduced factors.
CookieMonster
ECU is tuned to mods that are as follows:
Exhaust (I cored the cans)
Udder delete
Open air box
I wanna say O2 bypass but don't remember that one
I think I could've done a better job adjusting the trim though but with the way I had it before putting in the Brisk plugs, was acceptable.
