April 28, 2024, 09:46:38 PM
2001 M750 carb - need bolt that screws into emulsion tube
Topic: 2001 M750 carb - need bolt that screws into emulsion tube (Read 946 times)
justin-branam
May 06, 2019, 07:28:40 PM »
Finally got my rebuild kit, and everything was going great.... up until the point that one of the hex head bolts that screws into the end of the emulsion tube was stuck so good, that it sheared off. I had continually sprayed it with PB blaster, wd-40, etc, with no luck. What's done is done m, so long story short, I need a replacement. Know where I can find one? I noticed it appeared hollow. Does this matter? If not, can I just replace it with a regular brass bolt? Anybody know what size it would be?
Image here:
https://drive.google.com/file/d/1gC9gbuHHkzSyYN1Ij64gkhro3LMsB0yU/view?usp=drivesdk
justin-branam
Re: 2001 M750 carb - need bolt that screws into emulsion tube
May 07, 2019, 01:30:35 PM »
I think I may have found a fix. Since it does not appear that the bolt is anything special (PLEASE correct me if I'm wrong), I was able to find a brass flathead bolt the same size, on a dusty shelf, in the back corner of my local hardware store
. The threads are 10-32 in case anyone else is wondering. Can anyone confirm one way or the other if this is a viable solution or not? I got two screws, as I want to make sure both carbs are exactly the same.
Image is here:
https://drive.google.com/open?id=1LJrztEolA7NKvsADo5FZi5zkqsHNDv9U
May 07, 2019, 02:47:53 PM »
I'm pretty sure those screws need to be hollow to allow for needle clearance at closed throttle.
Thread is M5x0.8.
1992 Yamaha TDM850 ran the same carbs, I think 1HX-14565-00-00 is the part number, check with the Yammie dealer.
Powerbarn or other aftermarket carb parts boys may have em.
May 07, 2019, 02:58:24 PM »
I think Nick is correct about the reason, so the hollowing doesn't need to be rocket science, or military contract tolerance.
A resourceful guy would hollow out the hardware store bolts.
justin-branam
May 07, 2019, 03:00:56 PM »
You guys are correct! Just found out about the needles by trial and error, haha! I also have some good drill bits amd machinery at work. I'll give it a go, but if it doesn't work out, that part number looks like a winner. Thank you very much for the info!!!
May 07, 2019, 08:41:12 PM »
For limited length of engagement, and non-structural, 10-32 and M5x0.8 can be interchanged.
Suspecting that you bought nice nickel plated emulsion tubes.... I'd say run a M5x0.8 die over your 10-32 screws if they don't play well.
If you've got the desire and the equipment, give it a go!
NGL_BrSH
May 12, 2019, 04:00:27 AM »
I literally did this yesterday.
Definitely M5x0.8.
I really wanted to make mine out of brass because it's softer than Aluminum. Unfortunately I had trouble finding a donor brass bolt/rod. If you make the bolt out of steel you run the risk of damaging the Aluminum if you cross thread of don't thread the bolt correctly.
Don't forget some washers or o-rings.
