April 28, 2024, 01:04:49 PM *
Author Topic: Rear axle slider fitment question  (Read 891 times)
M900GP
« on: June 11, 2019, 03:08:31 PM »
Will a set of Speedymoto rear axle sliders for a standard 1098 (not R or S) fit on other Duc single-sided swingarms?  I understand the hubs are bigger on the 1098/1198 than on the smaller-hub bikes, so the wheels won't swap, but I didn't know if that also ruled out the axle sliders.  Oddly I didn't get a very clear answer from Speedymoto, so I thought I'd see if anyone here knows.
Thanks.  waytogo
« Reply #1 on: June 11, 2019, 07:17:40 PM »
The ID of the 'large axle' is quite a bit bigger, so I'd say that's a hard no.
M900GP
« Reply #2 on: June 12, 2019, 12:40:48 AM »
That's what I was thinking as well.  The word from Speedymoto wasn't that clear, not sure why.  Thanks!
« Reply #3 on: June 12, 2019, 07:37:55 AM »
IIRC, Speedymoto was absorbed by Motowheels a few years back.
So that may have effected the info you're getting.
About 2/3 of the way down this page:
https://motowheels.com/b-32130-891476-speedymoto.html
M900GP
« Reply #4 on: June 12, 2019, 09:13:41 AM »
Thanks, that helps.  I wasn't aware there was a difference between an early-production 2007 1098 and anything after that, in terms of swingarm ID/OD from one side to the next.  That shouldn't have filtered into what I was asking about with the Speedymoto folks, but maybe it did.  Anyway, all square now, thanks again.
« Reply #5 on: June 12, 2019, 10:17:55 AM »
From Motowheels website:
"Special Note! *Early 07'1098's have an axle that measures 42.7mm on both left and right sides. Later models 2007 1/2 and newer have a thicker left side axle with a 40mm ID and the right side is 42.7mm. If you have a 2007 please double check your left side axle before you order.* "
Big WTF on that, news to me.
Got a complete hub off of a '15 MTS12, axle's 43mm straight thru.
