WASP KIT RUNOUT
Started by koko64, June 26, 2019, 06:09:19 AM
I just purchased the last WASP intake kit from Todd at Bunbury Ducati in Western Australia. The intake kit is for an M1100Evo and comes complete with all the brackets, breather filters , etc required to mount the large velocity stacks and Ignition/electrical components. They are ceasing production and Todd said it was with some sadness that he put the last kit together.
I will report back when I test the kit (and find a bike to test it on).
greenmonster
M900 -97
MTS 1100s  -07
The biggest improvement was with the Sportclassics and Hypermotards with their very restrictive airboxes. The Intake Express website is down so a bunch of dyno charts are no longer available. I think the gains with the Monster are akin to that of a well designed open airbox, but the packaging restrictions on the Monsters are tight. I note that Todd tuned an M900ie but didn't use the WASP kit but opened and modified the airbox for a good gain. EVR made a carbon performance airbox with carbon velocity stacks  [drool] for the Hyper but it was the price of an M750. The packaging is even tighter on the M1100Evo with the TC and ABS modules. The WASP kit has brackets for the tidy location of those components so easy serviceability is also an issue.
cencalal
Koko, you may recall this from a couple of years ago:   http://www.ducatimonsterforum.org/index.php?topic=74219.0    ...just ignore the parts about how to post photos.  I recall seeing the kit you mention, but couldn't justify the price at the time, so I made my own from some S4 velocity stacks and pod filters and hose clamps. The photos from the old post show my first effort with foam UNI filters, which I eventually replaced with K&Ns.  The foam filters were just unbearably loud,even with earplugs, the K&Ns which have metal end caps are noticeably better.  Either filter an exact fit as are the stacks to the M695 elbows.  Cost about $80.  Sorry, still no dyno test data, but still the same grin every time I wind it on.
Ah, I remember, that was cool [thumbsup]. I had a similar set up on my Hyper Evo which was a mix of WASP and Corse Dynamics parts. Added about 10hp with vivid acceleration .
Cheers
cencalal
My initial impression when I changed to the closed end cap K&Ns was that there was a bit more power with the open ended foam filters.  I'm going to put the UNI filters back on just to compare, but I know I won't like the noise...
greenmonster
#6
QuoteI had a similar set up on my Hyper Evo which was a mix of WASP and Corse Dynamics parts. Added about 10hp with vivid acceleration .
Cheers
Did you make a thread here about it?
M900 -97
MTS 1100s  -07
greenmonster
M900 -97
MTS 1100s  -07
K&N barrel filters are not quite as long as those in the Corse Dynamics kit, but are a larger diameter at both ends. Cosi cosi. The WASP velocity stacks are respectively to a little wider in outer diameter to suit and have the golf ball dimples, but otherwise a similar design concept with big filters and velocity stacks tapering down to the TB diameter. The advantages of this kit are the specific dyno derived maps available and the neat stainless brackets for battery/ECU/ignition, PCV, ABS and DTC modules. Others may make nice brackets but I paid for the convenience of nice prefab parts as I'm not that handy.
greenmonster
Has anyone used C D or WASP velocity stacks on
a 1k/1100 w an opened airbox?
M900 -97
MTS 1100s  -07
I dont know how much work would need to be done, but it must be substantial. At least your Multi has a good airbox worth opening.
