Spiritual successor to the arai quantum 2?
Started by chipripper, August 20, 2019, 09:58:37 PM
chipripper
So I've had my helmet since 08, and it's starting to show it age on the inside. I've also gone well beyond the 5yr rule. Not a huge fan of the visor change mechanism but It's a perfect fit for my head shape, and I'll be sad to retire her to the old helmet shelf  Any suggestions on helmets with a similar fit, and good airflow? Any new features in the last 10yrs I should bolo for?
2008 S2R1000 black and white, mostly stock ;-)
Marving header, Velocity stacks, Pod filters, Flashed ECU to DP map, Polished valve covers and cam covers, SSR reverse shifter and inspection cover, Aelle adjustable pegs, Windscreen and cowl removal, Many plastic bits removed, Cut beer tray
S21FOLGORE
Quote from: chipripper on August 20, 2019, 09:58:37 PM
First,
There's no such thing as "5-year rule".
Read this about that subject.
http://www.ducatimonsterforum.org/index.php?topic=76572.msg1421072#msg1421072
Well, if the helmet is showing signs of wear and tear, and you feel like it's time to replace it, it is the time to replace it.
As for the fitment, I strongly suggest checking your head's CI first, if Quantum 2  really fits that well on your head.
(If your head shape and Quantum 2 is perfectly matched, your CI is probably higher than 86.)
chipripper
S21FOLGORE,
Thanks for the link! That was a very helpful, and informative read. I will have to get some good measurements of my head, and move out from there.
