Stuff You Find
Started by koko64, October 03, 2019, 05:54:18 PM
20191003_105613 by Tony Kokonis, on Flickr
I found the male to female connector safety clip on this metric cruiser just hanging off the hose and not fitted when I serviced this bike. A shop had been in there for substantial work and left it off. Lucky the two little tangs held on for dear life. See the little blue plastic thing in the pic.
20191003_105015 by Tony Kokonis, on Flickr
The two piece clip here. Glad the Ducati EFI fittings are more robust in comparison, so I'll not complain about them anymore.
20191004_102042 by Tony Kokonis, on Flickr
This particular metric cruiser has an integral fuel filter within the fuel pump.  The system only has a gauze pick up which requires regular replacement to avoid clagging the expensive pump (which is not serviceable).
20191004_102035 by Tony Kokonis, on Flickr
140,000kms later and the bike couldn't rev past half throttle. Amazing it ran.
Cup of tea anyone?
IMG_2504 by Tony Kokonis, on Flickr
For you Arachnophobes. At least the filter stopped it.
I'm sure Carlos can beat this with a pic of a tarantula in a velocity stack. :D
No pic, but back in 2006 I walked out of Flight Cycles to meet a rider who had just pulled up only to see him pushing the front engine mounting bolt of his 00 M750 back through the case.   :o :o :o
“Yeah, it always does that.” He said.  I pulled the bike immediately onto a lift and proceeded to fix it.  Turns out the nut was being held in the frame by the rubber plug!  I made a customer that day.   [clap]  I also added a few other fasteners to his bike before he left.
