Fork question for the pro’s
Started by Pinion, October 30, 2019, 06:10:16 AM
Pinion
I have 2 Showa adjustable forks, circa 2001
1 from a m900 sie
1 from a 900ssie
Are they the same inside?
Just wondering before I sell one and rebuild one
Will trade toilet paper for parts
greenohawk69
When you rebuild, would you share what you did, parts used and where obtained, and any other pertinent info?
"An enlightened people, and an energetic public opinion... will control and enchain the aristocratic spirit of the government." --Thomas Jefferson to Chevalier de Ouis, 1814
There are 4 boxes to be used in the defense of liberty:  Soap, Ballot, Jury and Ammo.  Please use in this order.  -- Ed Howdershelt
Pinion
MonsterHPD
Not a pro, but anyway ....
Are they 41 mm or 43 mm inner legs?
Not necessarily the same.
Are they the same length externally?
Pinion
Quote from: Speeddog on October 30, 2019, 09:15:33 AM
The ss housing is longer to provide for clipons
Pinion
MonsterHPD
Well,
if both are 43 mm, and both are adjustable, then they are similiar inside, but the total and relative lengths of the cartridge tube and cartridge rod are different.
And they indentically limited as far as function / performance is concerned (though better than the non-adjustables).
Pinion
Just wondering about valving
If one is worth rebuilding over the other
M900sie came with Ohlins remove reservoir, so did they ohlins inside front fork, or same across the board for the Showa adjustable
All the Showa valves are basically the same...restrictive.
Racetech will be your friend, but their recommended stacks don't necessarily work for everyone.
Quote from: MonsterHPD on October 30, 2019, 12:19:46 PM
Well,
This^
I've got a set of long forks that must be SS units, came off an '01 M900S oddly enough.
They're shorter travel compared to the Monster units.
Nice for above-the-triple clipons.
They'll suck for tubular bars.
Pinion
Quote from: Speeddog on October 30, 2019, 02:09:30 PM
This^
Yes they do, was running those on the monster I slapped together and was my daily
Pinion
#12
Based on that, and my experience, selling the longer ones and rebuilding the shorter
Thanks all for input. Will post progress and pics
Pinion
#13
So after all my exhausted research, looks like I'm going the way of total cartridge assembly replacement.
Have to decide which 1 of 3, Andreani,Axxion, or race tech. Have pricing for 2 of the three, will be contacting race tech for theirs
Pinion
Went with Andreani 105/D32E cartridges and spring set
