Electrical issue: battery at 13.3V, but no idiot lights, no start, no nothing
Started by Bergweiserus, December 01, 2019, 02:30:27 PM
Bergweiserus
This is incredibly frustrating...  hoping for some insight.  When I 'key-on' I get no idiot lights, no headlight, no clicking sound, no nothing....
Bike is a 1999 M900 (used to be a M750 before I did a motor swap in '06)
What I've checked so far:
Battery reads 13.3v.
Solenoid plug has been checked - firmly in place.
Getting 13.3v at the wires going to my starting toggle switch (replaced they key with a toggle).
Checked all fuses - they're good.
Unplugged and replugged both plugs going to handlebar controls along with various other plugs.
I am totally scratching my head on this one.....what is REALLY strange is when I had it in the 'key-on' position and was
standing there thinking to my self for a few minutes, the idiot lights came on and i was able to crank it over a couple times
but after clicking it off, now it's back to doing absolutely nothing.
I am wondering if it's my battery; it's a Ballistic 8-cell EVO2 that is about 7 years old and has seen quite a bit of extreme
weather.  BUT, if it's consistently reading 13.3, shouldn't that be enough to power up the headlight and idiot lights at least?
Thanks for any help  :)
'99 Dark with '94 large-valve 900.  Tons of mods...
2003 K1200GT...a few mods..
2011 Multistrada 1200S...lotsa mods (it's a beast)
greenohawk69
"An enlightened people, and an energetic public opinion... will control and enchain the aristocratic spirit of the government." --Thomas Jefferson to Chevalier de Ouis, 1814
There are 4 boxes to be used in the defense of liberty:  Soap, Ballot, Jury and Ammo.  Please use in this order.  -- Ed Howdershelt
Bergweiserus
Quote from: greenohawk69 on December 01, 2019, 02:44:14 PM
Year and model of bike
Woops!   Rookie mistake  [roll] :)
Bergweiserus
Quote from: ducpainter on December 01, 2019, 02:57:43 PM
Main relay?
I unplugged / replugged just for kicks and nothing.   I'm not sure how to tell if it's good or not.  Can i somehow use my volt-meter or is there another way?
Quote from: Bergweiserus on December 01, 2019, 03:02:47 PM
Half expose the pins see if what goes in comes out with your voltmeter.
Pull it out and give it a shake. Any rattle? They are cheap from the auto store. If its an old original Spanish one jyst replace it and buy a spare for the tool kit while you're there.
howie will be along to confirm, but contact 30 and 87 will bypass it.
Bergweiserus
OKAY, i don't care what everyone says - y'alls are geniuses  [laugh]
it worked!  i unplugged the relay (no rattle), plugged it back in and Voila!  Lights and all - fired right up.   I then gave the terminals a short blast of
DeoxIT 5 for good measure.
Good To Go!   THANK YOU all....  much appreciated.  Electrical stuff is my least favorite type of troubleshooting
[thumbsup] [bow_down] [beer]
Dont trust it though. Get a couple from the auto shop. Maybe corrosion or loose internal connection.
Where's Howie?
We can't diagnose and declare an issue 'solved' on our own. It doesn't work that way. It just doesn't  [bang]
[Dolph]
Bergweiserus
Quote from: koko64 on December 01, 2019, 03:36:50 PM
Will do, thanks for the help!
Quote from: stopintime on December 01, 2019, 03:49:16 PM
Where's Howie?  We can't diagnose and declare an issue 'solved' on our own. It doesn't work that way. It just doesn't  [bang]
[Dolph]
[laugh] [laugh]
Main relay?
Thanks again, homie  :)
Where's Howie?
[Dolph]
We're nor worthy. ;D
Seems y'all got along fine without me.  I would get a new relay though.  Cheap enough.
Thanks for the praise, but I can be as dumb as anyone else.  I moved the snow blower from it's summer home (shed) to it's winter home (garage).  I figured I might as well make sure it starts and runs.  Opened gas cap, looked in gas tank. Crank crank crank, no start.  Take sheet metal off to get to the carb.  All good.  Looked in gas tank again, but this time with strainer out.  No gas.  Put gasoline in, VROOM [bang]
