April 28, 2024, 05:10:05 PM
Anyone Tried Dellortos or FCR MX carbs on Long Manifolds?
Topic: Anyone Tried Dellortos or FCR MX carbs on Long Manifolds? (Read 3512 times)
January 23, 2020, 12:16:36 AM »
According to the Dellorto manual, the Dellorto carbs float bowls can handle up to 40 deg downdraft angle. The carburettored belt drive long manifolds appear to be at least on a 40 deg angle to my eye. Anyone tried Dellortos on the belt drive long manifolds? I was considering 36 or 38mm Dellortos rather than the very expensive FCRs or TDMRs. TM or VM 36 or 38 carbs are relatively cheap but I would have to modify the manifolds as they do not tolerate much tilt past the horizontal. If I can just bolt on some slide carbs to the stock manifolds it would be an easy fix.
Last Edit: January 28, 2020, 01:08:49 AM by koko64
Pinion
Re: Anyone Tried Dellortos on Long Manifolds?
January 23, 2020, 04:49:14 AM »
Not since I had a 69 t120
Will trade toilet paper for parts
January 23, 2020, 07:35:24 AM »
I heard that some ace tuner in Australia was going to try it.
January 23, 2020, 08:00:26 AM »
Re: Anyone Tried Dellortos or FXR MX Carbs on Long Manifolds?
January 23, 2020, 08:50:09 PM »
After much eyeballing the manifolds and 888 based frame spars, I can see a relatively "easy" way to cut n shut the manifolds for horizontal carbs like TMs. It requires a friendly machine/welding shop to modify spare manifolds accordingly. I figure if you have to cut n shut the manifolds for expensive Dellortos then may as well cut a 10-20mm wedge to use cheaper horizontal TM 36 or 38's. With stock manifolds I would be looking at used TDMR40's, but that raises the question of carb size for a 750 Monster for street scrambler work. Im thinking 36-38mm slide carbs with a choke/enrichener. Any thoughts on this?
With my own manifold work, TDMR's run at about $1200-1400 used and $1700 new, Dellortos for $1200-1300ish, TM's 500-600 new with cables and throttle, forget Ducati spec FCRs with no choke and now very very expensive. What about MX style horizontal FCR37 or 39's with a choke? They are cheaper and come up used on ebay.
Last Edit: January 28, 2020, 01:09:37 AM by koko64
Re: Anyone Tried Dellortos or FCR MX Carbs on Long Manifolds?
January 24, 2020, 01:41:57 AM »
FCR37 horizontal carbs off RMZ 250's are common with local parts dealers.They can be had for under 200 each and come with an accelerator pump and choke. Any thoughts?
Last Edit: January 28, 2020, 01:10:17 AM by koko64
January 24, 2020, 01:43:14 AM »
Quote from: Pinion on January 23, 2020, 04:49:14 AM
I bet you regret selling it.
Quote from: Speeddog on January 23, 2020, 07:35:24 AM
That Aussie's a fool
January 24, 2020, 11:06:04 AM »
Quote from: koko64 on January 24, 2020, 01:41:57 AM
Quick search says 250 four strokes are ~40 HP, so I think a pair would be just fine for a 750.
Peak torques seem to be occurring at 8k-9k rpm.
Factoring that by the displacement ratio of 2/3, gives 5.3k-6k.
My 750 had it's highest torque at 5.5k.
Looks worth a shot to me.
January 24, 2020, 01:55:02 PM »
Thanks mate. That confirms my guestimation based on 750 Pasos often running 36mm Dellortos. I remember the old adage of a flat slide carb flowing like a 2mm larger carb to an equivalent size butterfly carb.
Last Edit: January 28, 2020, 01:10:55 AM by koko64
Pinion
January 25, 2020, 07:52:29 AM »
Quote from: koko64 on January 24, 2020, 01:43:14 AM
Yes I do
greenmonster
January 25, 2020, 10:37:43 AM »
Quote
.FCR37 horizontal carbs off RMZ 250's
Could have different throttle cutaway, can affect ease to get good idle.
Throttles are numbered, like 2.1 .
M900 -97
MTS 1100s -07
January 25, 2020, 11:14:57 AM »
Thanks Gert👍
January 25, 2020, 11:55:56 PM »
An issue with the FCR MX37 carbs is that they were oem for various models with cast bell mouths to fit specific airboxes. The FCR MX 39's I've seen have the regular bolt on velocity stack or air box adapter. The 39's cost about 50 more per piece and are easier to fit up to my pod filters. I would prefer the smaller carbs however, so I'll see what can be done with the bell mouths of the 37's before I decide.
Last Edit: January 28, 2020, 01:11:40 AM by koko64
January 27, 2020, 07:06:08 PM »
images
by
Tony Kokonis
, on Flickr
Most of the used FCR MX 37's have these cast bell mouth/airbox adapters designed to fit specific model airboxes as oem equipment. Im trying to avoid this, so this has directed me more towards FCR MX 39's which usually have the bolt on airbox adapters/bell mouths. The 39's, although being a little more expensive, with these larger, bolt on airbox adapters allow me to use the K&N pod filters which I already have and save me modifying the cast version, which all saves money. I will also save time and money on jets and needles getting the 39's as I already have decent tuning data from tuning two sets of 39s and data from the forum (cheers Speeddog).
Last Edit: January 28, 2020, 01:12:10 AM by koko64
Reply #14 on:
January 27, 2020, 07:18:37 PM »
images (3)
by
Tony Kokonis
, on Flickr
This is what I can pick up for a few bucks more saving alot of hassle and money in the long run. See the bolt on stack/adapter? These are compatible with different filters I already have. The spigots are also in the ball park with my spare manifold rubbers compared to the 37's so its worth a change in plan to go with the 39's. Add in the money saved on brass and needles and it adds up quickly. I reckon the larger carbs are more likely to have adjustable slow air jet screws which are worth their weight.
Last Edit: January 28, 2020, 01:12:41 AM by koko64
