How to reset the maintenance reminder on Ducati with Magneti Marelli ECU
Started by S21FOLGORE, March 05, 2020, 10:18:13 PM
S21FOLGORE
1. turn ignition OFF
2. press and hold down the LEFT function button on the clock
3. while holding down the left function button, turn ignition ON and let the instrument panel run check-up cycle ( the pointers on the tach & speedo swing to full scale, then come back to zero)
4.turn ignition OFF
That's it. When ignition key is turned on next time, the LCD display no longer shows "MAint".
Works for older (2009 or earlier) Ducati with Magneti Marelli ECU.
Doesn't work for the bikes with Siemens ECU.
