April 27, 2024, 04:16:11 AM
Brake pad recommendations ?
Topic: Brake pad recommendations ? (Read 1123 times)
Timmy Tucker
Banninated
April 29, 2020, 02:12:36 PM »
Looking to swap out the front brake pads on my ‘07 S4RS, as I’ve managed to make the front tire chatter a few times under heavy braking. Assuming that the pads I currently have are stock, what’s a good recommendation for something a little less grippy?
1999 M750 - "Piggy"
2007 S4RS
Re: Brake pad recommendations ?
April 29, 2020, 02:42:23 PM »
Show us a pic of the old pads. Maybe they were aggressive sintered pads fitted at some time in the bikes life. Organic, non sintered pads are usually less aggressive in bite and initial take up.
Also consider the tyre and suspension set up.
Just shows how strong stock most Ducati brakes are. I had to do the same on my last M900, fierce brakes with heart stopping bite in low grip conditions.
Last Edit: April 29, 2020, 02:46:49 PM by koko64
Timmy Tucker
Banninated
April 29, 2020, 06:40:24 PM »
It’s supposed to rain all day tomorrow, so I’ll see if I can pull a caliper and get a pad off for pics.
1999 M750 - "Piggy"
2007 S4RS
Online
April 29, 2020, 09:16:48 PM »
Does that bike have 4 pad calipers? I sorta remember something about installing restricters to the calipers as a factory fix to reduce vibration, the idea being to slow the application. I will see if I could find anything on the interwebs. Koko's suggestion of less aggressive pads may well be an easier and better solution. You might also want to make sure you are not bottoming the forks on hard braking.
