Monsterlover rejoins the fold
Started by Monsterlover, August 20, 2020, 05:01:00 PM
Quote from: Monsterlover on September 20, 2020, 02:54:10 PM
Would .000 be an issue as things heat up?  Shouldn't there be a little something for expansion?
No.
As things heat up, closer specs open up and opener specs close up due to the valve stem grows due to the heat expansion.
Quote from: Duck-Stew on September 20, 2020, 08:45:49 PM
Yeah that makes sense
Dammit I need to check for posts before typing. What Stu said.
I'm not sure of what the true ROI is on chasing the last 0.001" or 0.002" out of the closer clearance.
It'd be an interesting test, set all closers to 0.003" and ride it, then get 'em as close to 0 then ride again.
Better yet do that on a dyno!
I'd try to trick Brad or Ducvet into doing that but it I like them and I think they'd see right through the ruse.
The mechanism is happier with 0, as it's not banging around.
Closers up around 0.010" they definitely run shitty and it accelerates the wear on the half rings and shims, likely valves too but that's really hard to see.
IMO, the shitty running with loose closers is mostly due to that effectively retarding intake closing.
Brad has thoroughly documented the benefits of proper closing timing, so I think there's something to my theory.
I usually wrote that spec on my customers receipts as:  0.000+”. Just to show that it wasn't exactly 0, just was between 0.000” & 0.001”.
Quote from: Duck-Stew on September 21, 2020, 11:22:50 AM
Spec printed under my ss tank says .0008 on closers and .004 on openers so that would match what you setup
Fiddled with valves tonight.
Here's where things sit currently. Let me know how this looks.
Front cylinder-
Intake open .005
Intake close .000
Exhaust open .005
Exhaust close .000+ / .0005
Rear cylinder-
Intake open .004
Intake close .001
Exhaust open .004+
Exhaust close .000 + /.0005
I think these are a lot better but one thing is troubling me. I have measurable clearance on both closers on the rear cylinder but I still have drag on the cam when I spin it without the opening rocker arms engaging anything.
Even though everything is well within spec, I feel like I need to open them up more to get the drag off the cam. Am I right or do I leave it alone and pack it all back up?
Swapped some clutch stuff over from that spare engine. The cover had some dings and scratches on it but it matched the bike so I left it as is.
Generated by http://tools.sportscard.trade
Quote from: Duck-Stew on September 21, 2020, 07:51:45 PM
Drag on cam = bad.
So I figured. How can I have clearance I can measure and cam drag at the same time?
Is that really a thing?
Speeddog mentioned cams not being machined perfectly earlier in the thread.  That would get my vote.
Quote from: Duck-Stew on September 21, 2020, 08:49:55 PM
I missed that. That scenario seems... unlikely. For that to be true the base circle would have to be either out of round or off center. Or both.
I'm not a 2v scientist like you guys are though. It's just perplexing. The way it feels I can't help but wonder if I'm going to end up back closer to the .003 I started with.
Not the base circles, those are easy (I would imagine).  The transition onto and off of cam lobes would be tricky ai would think.
Anyways...  Other option is to just leave it as it is.
Maybe what you're describing as drag is something else.
Like you say...how is it possible to have measurable clearance and drag at the same time?
Did you feel the same thing at .003 on the closers?
