April 28, 2024, 11:24:58 PM
Monsterlover rejoins the fold
13
14
15
16
19
Topic: Monsterlover rejoins the fold (Read 38324 times)
Re: Monsterlover rejoins the fold
Reply #195 on:
September 24, 2020, 03:04:56 PM »
Eric would get that rear cyl exhaust closer to .000
You could replace the half rings and get there, but after a few revolutions you'd be in the same place.
The best kind of whore is a
Reply #196 on:
September 24, 2020, 03:09:37 PM »
Quote from: ducpainter on September 24, 2020, 03:04:56 PM
I had it closer to zero on both (rear cyl-) and I had drag on the cam. Went .0005 at a time until it went away.
Here we are.
Reply #197 on:
September 25, 2020, 06:51:53 AM »
Chasing tenths out of this system requires a pile of shims and bucket of patience.
Problem is we can't measure the position of the actual working surface where the half-ring sits in a closer shim.
We can measure nearby but we're talking tenths not horseshoes.
Swarf and burrs and brand new halfrings aren't
quite
as flat as used ones.
And used valves don't seat eeeexactly the same every time.
Reply #198 on:
September 25, 2020, 06:55:42 AM »
Hypothetical scenario here...
What if some of the half rings were installed upside down? In other words opposite of the way they were originally oriented.
Reply #199 on:
September 25, 2020, 10:06:03 AM »
Quote from: Monsterlover on September 25, 2020, 06:55:42 AM
Theoretically, the new surface will wear in and the clearance will increase a bit quicker.
Reply #200 on:
September 25, 2020, 10:15:50 AM »
Theoretically, these would all be on the front cylinder. So they would, theoretically, be very easy to get to.
Reply #201 on:
September 25, 2020, 10:44:09 AM »
You're talking about .0005-.001.
If you wear in both sides on all of them, it won't matter anymore.
Reply #202 on:
September 25, 2020, 10:50:01 AM »
Symmetry is good sometimes.
Theoretically.
Reply #203 on:
September 25, 2020, 11:23:10 AM »
Quote from: Monsterlover on September 25, 2020, 10:50:01 AM
Theoretically.
If you ride that thing like your KTM the half rings won't last long enough to matter which side is up.
Reply #204 on:
September 25, 2020, 11:24:54 AM »
My first job, we actually had our own electron microscope.
I was amazed then and probably would be even now.
The running joke was if you couldn't find something wrong using normal inspection then the eScope could find a huge
(1)
_____ somewhere and that _____ was obviously the problem.
(1) Size being relative after all.
Ideally, one would flip the half rings every 1k miles a few times then every 6k would be fine after that.
I mean people rotate their tires so it should be no issue.
This is of course the proper time to mention you could've fitted MBP collets and avoided a lot of these dilemmas.
But no worries you would have had other substitute dilemmas (We'd have seen to that).
Seriously the MBP bits are heaps easier to handle and cannot be installed upside down and on 7mm stuff that's even more awesome.
Symmetry is theoretical, there's just varying degrees of closeness.
Quote from: ducpainter on September 25, 2020, 11:23:10 AM
This is relevant.
Reply #205 on:
September 25, 2020, 11:28:00 AM »
You guys make me sound abusive
Ddan
Some of my best friends are whores
Reply #206 on:
September 25, 2020, 02:33:27 PM »
And?
Quote from: Monsterlover on September 25, 2020, 11:28:00 AM
1992 900 SS,
currently a pile of parts.
Now running
flogged successfully
NHMS 12 customized. Twice. T3 too.
Ducati Monster Forum at
www.ducatimonsterforum.org
Reply #207 on:
September 25, 2020, 02:45:08 PM »
Quote from: Ddan on September 25, 2020, 02:33:27 PM
And?
This thread is not for people that don't own Supersports to antagonize people that do
None of you are wrong.
Reply #208 on:
September 25, 2020, 04:31:20 PM »
Unfortunately I do not own one of the handsome tanks so I've just got a bunch of SuperSport bits really.
DP did touch on a truth, all of the clearances seem to stay nicer longer if you don't rev the snot out of it.
Peak torque at 5k and peak power at 7k you can braap around all day long 3k to 6k with big lines and it's great.
Reply #209 on:
September 25, 2020, 04:49:20 PM »
I tend to run engines low. I cruise where it feels best. Generally right before the torque curve ramps up.
That lets me do a lot of acceleration/deceleration with just throttle without shifting
13
14
15
16
19
