M696 air filter fluid?
Started by alibaba, September 29, 2020, 04:02:39 PM
alibaba
2009 M696 installing new air filter.
Should I install it dry or use a special product to wet the filter?
How much?
Recommendations?
It depends on the filter. What type and brand are you looking at?
alibaba
Replacing original equipment Ducati filter with a new one the same.
If its yellow paper, then no fluid. Most oem are paper.
Fluid is for foam, cotton gauze, etc and that varies per type and Mfr. K&N cotton pleat use a specific spray while foam filters often use a special oil you massage in.
Quote from: koko64 on September 29, 2020, 05:55:22 PM
^ This.
Same shelf as blinker fluid   ;D
Quote from: stopintime on September 30, 2020, 05:38:39 AM
Thanks. Now I don't have to go there. ;D
Right next to the muffler bearings.
If you see a box of round tuits I really need those send em over.
...but who would have thunk...exhaust fluid is there.
