2007 S2R 800 Exaust bracket
Started by sandromxp, November 04, 2020, 04:16:22 PM
sandromxp
I just changed the midpipe on my S2R and the previous owner had a set I'd Danmoto pipes on it. Unfortunately the bracket is really flimsy and I want to change it. I've  Been looking everywhere and I can't find any brackets. I saw termi has a nice setup and I'm trying to find the 2 part can clamp. Dose anyone know where I can get one? Or if someone sells a bracket kit?
Sandro
Which bracket, where?
Picture if you can (host on lickr postimage or similar, then link to them)  [thumbsup]
sandromxp
This is the termi one I was looking at. If I could get the 2 part clamp I could make the rest. Or if someone has a full set I'd would buy it
https://i.postimg.cc/Yq8MD6V7/57-A4-EAC4-4980-4-BF7-9-BA8-FA622-A49-E853.png
Ok - those are often called "45 degree" exhausts - a little bit smaller diameter than the more common "shotgun".
The "45 degree" type of bracket, a double version, is quite common on many exhaust brands. Probably available as a generic accessory (if the smaller diameter isn't a problem...)
The bracket from the exhaust and up to the frame is simple enough, but can be difficult to make. It has to be stiff enough to kep the exhaust from flapping around, but soft enough to keep it from cracking.
sandromxp
Thanks! I'll start looking for one now. I'm going to use a 1/8” aluminum or steel bracket it should be short so it will be stiff. Looks like 15cm long. Do you have any idea who would have the clamp?
Sandro
