ML builds an old truck
Started by Monsterlover, March 19, 2021, 07:59:32 PM
 [thumbsup]
Lot's of odd surfaces on that paint job. I recommend you use something that isn't likely to lift when you're faced with the inevitable touch ups. ;D
Quote from: ducpainter on June 10, 2023, 08:42:09 AM
[thumbsup]
Honestly, primer and satin finish rustoleum with some hardener.
Kopfjäger
Quote from: Monsterlover on June 10, 2023, 08:57:37 AM
Rustoleum is straight enamel you might have to wait a week before you attempt any touch ups.. Just read the can for re-coat times. Nothing more frustrating than touching something up and having it wrinkle.
Quote from: ducpainter on June 10, 2023, 11:02:05 AM
I can live with a week. I really only get Friday Saturday Sunday to work on it.
I'll try not to miss a spot though ;D
Quote from: Monsterlover on June 10, 2023, 11:25:50 AM
If you get everything on the first try, you're in the wrong line of work. ;D
Randimus Maximus
Great to see the progress!
Speedbag
I finished the last bead of weld on the frame tonight.
:D
Short update today.
I got the frame all finished up, prepped and painted. Unfortunately, due to a variety of errors, I had adhesion problems.
After graduating from ducpainter university I was able to strip all that off and start over. Went after it with a two-part epoxy primer and a nice kit from SEM called hot rod black. This time it was a success.
I modified all the suspension mounting bolts to be more dangerous. Because pointy things are cool.
2023-07-04_10-23-42 by Kevin Ames, on Flickr
Primer
2023-07-04_10-23-58 by Kevin Ames, on Flickr
Reassembly after paint
2023-07-04_10-24-13 by Kevin Ames, on Flickr
2023-07-04_10-24-21 by Kevin Ames, on Flickr
I had a crew of people over this past weekend to help put the bed in the cab on. This is how it currently looks.
2023-07-04_10-24-33 by Kevin Ames, on Flickr
Lots more to come...
Also, it's been 2 years since I brought this thing home. And maybe a year and a half since I started really working on it hard.
And before anybody asks, I cold blued the bolts so they wouldn't rust.
I had to throw the front on. I couldn't help it.
2023-07-04_03-14-45 by Kevin Ames, on Flickr
2023-07-04_03-14-53 by Kevin Ames, on Flickr
2023-07-04_03-15-00 by Kevin Ames, on Flickr
