S2r 800 wet clutch
Started by Airborne, April 09, 2021, 02:39:06 PM
Airborne
The time has come to replace my clutch on my s2r 800. I am confident the issue is just worn plates. I watched a ca cycle works video on how to replace the wet clutch in the 620, however, when I emailed Chris at CA cycle works he informed me the 800's wet clutch is different. I know it's a slipper, but how much of a job am I getting myself into here?
2007 Monster S2R, Vespa GTS 300, 2023 Triumph Tiger 900 Rally Pro, Vino 125
Four times more fiddly for an amateur. 1.5 times more or an expert. On average, 2.75 more fiddly  8)
Videos are available (also from Chris?)
I'm soon on my seventh clutch (half of them with a normal, non APTC clutch) and none have been worn. At all. They're just glazed. I haven't tried, but wonder if they could live another life if sanded down a bit.
caperix
Its not too much worse to replace the discs on an aptc bike, like stopintime said just more fiddly.  I would go the extra step & remove the basket to check the spring dampers & retorque the basket nut as both can cause issues.
Airborne
Order this?
https://www.ebay.com/itm/254425608557
Maybe not the best example of an add, but the ducabike kit? Heard the Barnett wasn't great...?
And also the gasket for around the clutch cover?
OEM Ducati is a good choice. Maybe the Ducabike is too (maybe it's OEM in another box).
Be careful with the tiny springs inside the assembly. Remember that the last disc goes in it's own slot, a little off the others.
Checking the spring dampers is a VERY good idea  [thumbsup] Take a video of them and show us, if you can.
After two failures I decided that I had used all my luck and changed the complete unit. I think it was from a 750. No more dual mass drive primary gear. No more spring damper piece of garbage driven primary gear (under the basket). No more silly "self servo" grabby APTC patent.
If the plates are just glazed and you're willing to try this:
(NOTE!!  IF YOU PROCEED AND GET HURT, YOU FOLLOWED ADVICE FROM SOMEONE ON THE INTERNET.  (I'm not liable...))
Try soaking the frictions in gasoline and lighting on fire.  During my M750 dry clutch weirdness, I oil soaked a brand new set of frictions and a friend gave me the idea.  It worked.  YMMV.
(Please be careful if you try this, ok?!?)
General consensus is that Barnett clutches aren't good.  I once put a set in a high mileage MTS1000 and they performed worse than the 120,000 mile set of used plates we removed.
Barnett plates were grabby.
Airborne
Quote from: stopintime on April 10, 2021, 12:50:20 AM
When I get around to doing it, I will put a video up. Currently moving along on building an airplane but trying not to let the monster sit too long...
Quote from: Airborne on April 10, 2021, 06:36:45 PM
The spring pockets are tight in the beginning. Then the springs start rattling around and after a 'while' the pockets are large enough for the springs to escape. Bad. Very bad. Of course, it doesn't happen to everyone, but often enough to make checking worth the extra effort.
Spain
I believe your slipper clutch is similar to a 695 I once had. There is a specific holding tool you will need, let me know if you have trouble finding one. I think I still have it my tool chest. Also, Ducati uses three holders to keep the stack together, which are essentially M3x45 bolts.
Airborne
Quote from: Spain on April 12, 2021, 09:01:02 AM
Are you talking about a castle nut remover? I've heard of having to make one... time consuming... I'll ship it back..
Duck-EZ
I think he is referring to the basket holding tool it looks like a big boxend wrench laser/water jet cut out of flat stock; that indexes on the exterior teeth of the basket assembly. A lot are sold are for the newer wet clutches and do not work on the 800/695. Although many sellers lump all the wet clutches and list it as applicable. Ass-k me how I know [bang]. Someone may chime in on which one actually works for the early wet clutches. You can also just use the rear brake to counter your torque when breaking or tightening the main nut.
2006 Black N Tangy S2RS
