Hanging revs?
Started by greenmonster, April 29, 2021, 12:17:10 PM
greenmonster
If the throttle cables ain't stickin,
what else could cause revs stickin at high revs
(1100DS engine)?
Broken TPS, ECU or what?
Battery ok. Fuel lines ok.
M900 -97
MTS 1100s  -07
Speeddog once told me about sticky "servo" idle systems (works like a servo but is really an air system for the ECU to control idle). It should be forcing the idle down to the programmed number. They may need a clean as when dirty can cause erratic idle. It's a bit of work to get to it and clean it. Otherwise maybe the TPS?
Often referred to as ICV (Idle Control Valve). I've never had to deal with one here.
I imagine salt on roads, bikes sitting during long winters, high moisture levels, etc all contribute to sticky operation.
Does your bike have a carbon canister like California?
