possible to swap out external brake reservoirs without bleeding system?
Started by booger, May 26, 2021, 11:37:52 AM
booger
Hi, as the title states is this possible? I mean, pinch off the little hose, empty the original reservoir, disconnect the hose at the original reservoir, mount new reservoir, connect hose to new reservoir, pour the fluid into the new reservoir, done.
Does this process appear sound? I got some replacement Brembo pee cups in the newer smoked clear and I want to swap 'em out with no drama.  Thx
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
booger
Thanks. Seemed like a dumb question but I don't consider myself an expert in such things and needed validation.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2008 BMW R1200 GSA
DuciD03
... yes you can do it: but will you introduce air into the master hand break cylinder?
...  with the cap off, try gently flicking the break lever, ever so slightly, pull in then let go, after connecting everything; infract do this before and see if any tiny bubbles appear in the reservoir, and after ... post back findings.
... and although bleeding breaks properly seems a pain; fresh fluid is a good thing.
[Dolph]
.... all the world is yours.
If the ports in the master are covered in fluid air will not be introduced.
booger
Quote from: DuciD03 on May 27, 2021, 09:47:59 PM... and although bleeding breaks properly seems a pain; fresh fluid is a good thing.
[Dolph]
I agree, it' a good thing but the reason I enquired about doing it without bleeding the system is that I had already had the fluid replaced with new very recently and have only ridden the bike once. I'd prefer to avoid the unnecessary work & expense of bleeding it again.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2008 BMW R1200 GSA
DuciD03
