April 25, 2024, 03:44:15 PM
DP clutch slave=Oberon?
Topic: DP clutch slave=Oberon? (Read 1673 times)
greenmonster
October 28, 2021, 04:21:15 AM »
As headline says,
is the Ducati Performance clutch slave made by Oberon?
Looks like it.
What slave do you prefer?
M900 -97
MTS 1100s -07
Re: DP clutch slave=Oberon?
October 28, 2021, 05:47:56 AM »
No idea who makes the DP slave. Can't go wrong with Oberon.
S2R 800 '07
October 28, 2021, 10:28:18 AM »
Why? On which bike?
Stock bore? New bore?
AFAIK/IIRC ... ? ... DP was 28mm vs many other aftermarket cylinders at or over 30mm
greenmonster
October 29, 2021, 04:42:37 AM »
Replacing it.
MTS 1100s.
32 mm.
M900 -97
MTS 1100s -07
S2R 800 '07
October 29, 2021, 06:52:14 AM »
I think Oberon is 29....
That'll help quite a lot. The wet clutches require a modest bore, to have enough throw between fully engaged and fully disengaged.
