Showa same upper legs?
Started by greenmonster, October 29, 2021, 05:54:04 AM
greenmonster
I have Showa adjustable (well... [roll]) from a -92 SS
on my Monster.
Are the upper legs, anodisized part, the same from a
nonadjustable 750SS  -92?
I just need to switch these 2 parts,
the 750 legs to my forks.
Mine are 50/54, 440mm long.
Don't think Showa altered these for so similar forks.
Edit: Bearing pipe same, 41 mm both.
M900 -97
MTS 1100s  -07
If they're both Showa, the odds are good if the Showa adj and non adj forks look exactly the same in castings. Just with the adj version there was a change in the 90's to the seal holding section on the upper. The anodising is different too, so watch out for that.
