S2R tail chop
Started by Mar-Vel, November 07, 2021, 03:30:38 PM
Mar-Vel
Hey guys new Ducati S2R 1000 owner and new to the the forum , I just did the tail chop but cant seem to find a license plate/rear light bracket , I know a lot of people have done this mod and bought the bracket can anybody steer me In the right direction .
Thanks .
Mar-Vel
#1
NM guys I found one....2006 S2R wheres the flasher unit located ?
Inside the instrument cluster, not a replaceable unit.  If you want to run LED signals use resistors.
You might like to check in here before you get too indebted to the benefit of the collective DMF wisdom  ;D
http://www.ducatimonsterforum.org/index.php?board=14.0
Mar-Vel
thump
Might be too late but I used this, also fits your S2R:
https://www.ducatimonstertailchop.com/collections/ducati-monster-fender-eliminator-tailchop-gen1/products/ducati-monster-tail-chop-stealth-fender-kit
Hides the plate under the seat. You do need to crank up the height adjuster and stiffen the preload to keep it visible when you're seated.
My toolbox is full of hammers. Because the world is full of nails.
2003 M800 dark
