2007 695 duplicate key problem
Started by gentlemanjim, December 15, 2021, 05:52:46 PM
gentlemanjim
I bought it used with only 6,000 miles stock and like new.  Only have one black key, no red key or code card.  How can I get an extra key?  I wouldn't care if I needed to disarm the transponder if needed.
There are companies that are able to clone keys. Or you could have the ECU reflashed to eliminate the immobiliser.
I would kill the immobilizer.   The system was problematic on that bike.  You might want to make sure it was not already flashed.  See if it starts with the antenna disconnected.
gentlemanjim
Under the ignition lock cover. It's wires and connector are close by and more or less open/visible/accessible. Easy piecy
gentlemanjim
