2 b sure, 900 head assembly
Started by greenmonster, December 27, 2021, 06:01:06 AM
greenmonster
Been a while since l did this last time, 10 years or so, so memory a little rusty...
1. Is this correct
https://www.bike-parts-ducati.com/ducati-motorcycle/Monster/1998/Monster_900/Monster-900/CAMSHAFT/676/2311/0/676. ?
My Haynes shows #19 w sealed side outwards, not towards cam lobes.
2. All parts in correct order, is it just to tighten #1 (new of course) and all will be proper w correct tension?
Have a vague memory of that #8 must be in precise right position to not bind #9 (or the speedo gear) and to not stress bearings
#8 & #13.
3. Anything else to look out for?
M900 -97
MTS 1100s  -07
MonsterHPD
Morning,
this is what it looks like on my old, on-the-shelf and sa far as I know never-changed ST2 heads:
2021-12-28 10.30.29 by torbjörn bergström, on Flickr
I don't remember what I did on the m800, but it's still running. I suppose it has to do with what the oiling bore is for ...
greenmonster
Hmmm, seems many have holiday absence...
2 bids so far, thx Thorbjörn, and my parts dealer (Biscaya) says open end towards lobes.
So altogether, 4 bids, 2 vs 2. [roll]
M900 -97
MTS 1100s  -07
The seal on the cap of my old 94 M900 is inwards but the outer seal on the belt side is outwards. I expected the seals to all be outwards.
The old oem manual gave no instruction. :P
Edit. I posted some incorrect info re the oil circulation and have deleted it.
Don't know what I was thinking. Please ignore it.
The lip of the seal, the part with the spring, should face the source of the oil.
The oil feed is definitely into the cavity outboard of the bearing so the seal lip faces it as you say.
greenmonster
Quote.The lip of the seal, the part with the spring, should face the source of the oil.
Quote.The oil feed is definitely into the cavity outboard of the bearing so the seal lip faces it as you say.
Seems logical, maybe we have a winner, open end towards cavity, not lobes. :)
M900 -97
MTS 1100s  -07
greenmonster
Sooo, how about no 2, just screw it together and all will be dandy?
M900 -97
MTS 1100s  -07
Quote from: greenmonster on January 01, 2022, 07:00:38 AM
I don't know about that part. Tony has a factory workshop manual.
Get the torque right. [thumbsup]
Factory manual says :
69-74 Nm cam pulley nuts
59-64 Nm on driveshaft
Values are rounded.
Haynes says 70-75 & 60-65.
