What have you done to your 767 today?
Started by marker, May 24, 2022, 12:50:44 PM
marker
Weather has finally improved, so I've done few things that I was putting off for a while.
Mainly un-dressing (removing the side plastic covers - four in total), relocating the rectifier plus some other small things.
EDITED to add: My apologies if imma repeating something that has been already done and covered by someone else  ;)
Cheers!!
marker
#1
Double-post, sorry....
De-plastic'ing is good  [thumbsup]
What have you relocated?
marker
Quote from: stopintime on May 24, 2022, 01:54:47 PM
Not much just yet - Voltage regulator (used to be under the R/H plastic fly-catch) and its harness. Its in front of the breathing apparatus now...
The resulting holes (threaded / grommets) have been covered with rather obnoxiously looking aluminum buttons, etc.
Nice turn signals. What brand are they?
marker
Quote from: koko64 on June 02, 2022, 03:41:09 AM
Thanks! They're Ducati Performance units.
They look great, not too small and have a classy style. I'm thinking of replacing the pigs ears on my Evo1100.
marker
marker
marker
#11
I recently scored a nice Ducati tank bag. The problem was, it came with the MultiStrada mounting ring...
But we live for the challenge, right? An hour later (and only one scrapped piece, lol), my homemade ring proudly sits in place:
But that's not all, boys and girls! The bag came with the USB charger and bunch of slick cables as well, so I just kept going.
I decided to repurpose the 12MM plug that I've had laying around (leftover from the 2005 Multi 1000DS, I think).
The upper handlebar clamp seemed to be a "natural" location for it, so I milled small pocket, and drilled / tapped 5MM mounting hole.
A bit more cutting / machining / sanding converted a piece of aluminum flatbar into the plug mount.
I tapped into the Daytime Light wire, and voila! There's my 12VDC:
Now I can charge my phone on the bike if need be, not to mention riding around with my GPS on without worrying about the phone going flat.
And no, my cluster view is not obstructed at all  ;)
marker
Be heard, or else!
The factory "Meep, Meep" pathetic imitation of a horn has been replaced with the loud as f**k duo:
Also, the mini-windscreen joined the other take-off parts.
Much better now.
I think, at least  8)
