I recommend option 3.
The satisfaction of learning is in itself worth quite a lot. The major reason to rebuild is that it will then be better than new - blueprinted, not just "within spec". In the long run this is cost effective. Add a mild tune while you're in there (port & polish + Dyno work).
Could be an exciting project with motor hop ups.
