Battery not charging on Monster 2009
Started by freshmilk, March 18, 2023, 10:57:48 PM
freshmilk
Anyone have experience with Monster battery not charging?
If stator diagnosed as OK, regulator replaced, what are the other suspects?
SHORT
  • Battery starts at 12.3v and ends 3-4mile ride at 10.5v
  • Motorcycle Mechanic (MM) voltage tested stator and OK
  • MM recommended replace REGULATOR but battery still not charging
  • Rotating through 2 different batteries and both end with low voltage
  • Acid battery 18mths & 3 mths old
LONG
  • Bike (12,500 miles) complete shut down at traffic stop and would not start again
  • Had it towed
  • Figured it was bad battery and bought Li-Ion battery but that died
  • Went to mech shop for help and they tested with voltage meter
  • Battery and Stator ruled out as OK and replaced regulator as likely culprit
  • Battery still not charging and voltage reading in the 10s according to bike OSD
  • Spark plugs replaced
  • Never had issues with bike running until 3 months ago with the shut down
  • Installed, pigtail for battery tenderer, front and rear cameras
  • Using Noco GENIUS1 to charge batteries. Supports acid, AGM and Li-Ion
  • YTX14H-BS 18mth old
  • Caltric Agm Battery 3mth old
Check the large fuse for the alternator. It's not in the fuse block. It's in line near the battery.
greenmonster
#2
Wiring to/from regulator OK? Check at engine block and connectors.
What regulator did you buy?
M900 -97
MTS 1100s  -07
freshmilk
Quote from: ducpainter on March 19, 2023, 04:04:11 AM
Will try replacing all the fuses to rule them out.  Thanks for highlighting the alternator fuse
freshmilk
Quote from: greenmonster on March 19, 2023, 05:09:00 AM
I bought a Ducati OEM regulator
freshmilk
For anyone else who has similar issues, turned out to be the regulator.
Bought a new regulator from Amazon for USD25 and now the instrument panel shows 13.8-14.3v.
Thanks to everyone for their input and suggestions
greenmonster
#6
Quote.I bought a Ducati OEM regulator
Quote.Bought a new regulator from Amazon for USD25
So why didn`t the Duc one work?!?
M900 -97
MTS 1100s  -07
