2023 Monster SP rear static sag
Started by GreasySnipe, July 15, 2023, 11:50:09 PM
GreasySnipe
I wound up adding to the stable recently, I got a '23 937 SP and have been enjoying it but the suspension felt off (just like most monsters new I've rode or had) So I started after getting some mileage on it by checking my sag numbers, front is 25 static, rider(me 170 lbs with gear/backpack for work) sag is 45 @ factory settings (5 in from fully unloaded, 1 turn is 1mm preload). The back is where it gets interesting- Zero static, Rider is 25 mm. The adjuster ring is 5 threads from fully unloaded. I added 5 turns(5mm preload) to the front forks as it felt weight was being pushed forward and it helped make it feel more neutral but still no static in the rear. I'm thinking it is over sprung in the rear and slightly under in the front in keeping with Monster tradition but I wanted to start off with the rear as the zero static is a problem. I cannot for the life of me locate anything on this spring part number or series other than it is what is described as a demo spring. The number is 01106-08-80-140, Anyone have any info on that?
And the Stable, the 796, the 937, the Scrambler
2011 Monster 796
2010 Street Fighter
2013 848 Evo
2022 Scrambler Nightshift
2023 Triumph Speed Triple 1200 RS
2023 Monster 937 SP
Another poo poo from the 'engineers' in Bologna.
I would HIGHLY recommend changing the springs to linear  [thumbsup]  If that's not happening, more preload front and less preload rear. Also work on the damping.
