Finally my 2003 oem rear turn signal broke
Started by mitt, August 24, 2023, 06:25:14 PM
Hi everyone.  Long time member here, even a DMF flounder some would say.  Haven't been around much but trying to get back into 2 wheels with motors.
My 2003 M1000 DS monster needs new rear turn signals, one finally broke (probably my 14yo getting on and off the pillion seat).  I did a search but most posts are from 3+ years ago with part number and vendor recommendations that are now defunct.
What says the community for good and reasonable rear turn lights and sources?  I do not want integrated with tail light.  I also do not want micro LEDs.  I want something that fits the 2003 era monster style and is ideally bolt on, although I do have access to machine shop to make adapters if needed.
thanks-
Another Flounder!!! Good that you kept the Monster.
Stock beer tray? Anything BUT stock will look strange because most/all are designed to fit on a flat large'ish surface, with straight stalks, versus stock which are formed to fit. Another issue is that two out of the three holes on a stock solution will be empty if you choose a generic after market light (yes, there are adapter plates to hide the holes).
Yes, stock beer tray but have a plate relocator.   Looks like the oem signals use a 6mm bolt.  I was wondering about the extra holes and anti rotation.
While taking stuff apart last night I can't find one of these spacers that go into the rubber isolators.  Must of dropped out and rolled  [bang]
https://www.flickr.com/photos/26466518@N02/53139835762
spacerz by mitt1000, on Flickr
Are OEM not available, too expensive, or undesirable?
.... those spacers like their freedom more than serving us.
Quote from: ducpainter on August 25, 2023, 05:38:34 AM
I haven't checked yet.  I might just go with OEM if I don't see any aftermarket I like.
I have the smaller tray and went with these, with 23 watt bulbs. They have a few hundred options. Scroll a little.
https://www.motorcyclestorehouse.com/product/940888
Quote from: mitt on August 25, 2023, 06:21:20 AM
Personally, I like the OEM signals on the M series Monsters as well as anything else I've seen.
Looks like they're available for $40 and change.
Yep, just looked them up on Ducati Omaha.
If that spacer is for the tail light, new part number 7161411A pack for 3 for $6.36.
Welcome back Mitt!
Quote from: Howie on August 25, 2023, 07:14:45 AM
Welcome back Mitt!
Thanks for the welcome back!.  An update after a little wait for parts, I did order a replacement and the spacers from Ducati Omaha.  Came from factory.  I installed it, and then like I anticipated it was enough different in the lens color than the 20 year old other signal I had to order a new one for it also so they matched.  Everything good now!
