August 31, 2024, 10:50:23 PM
Which compression tester should I get?
Topic: Which compression tester should I get? (Read 1475 times)
S2R 800 '07
September 24, 2023, 02:41:43 AM »
My engine guy asked me to do a compression test to help our diagnostic work.
Fuel prices makes it cheaper to buy a kit and do it myself, rather than travel two hours t/r to my dealer (after just one use).
The cheapest kit has 14 and 18 mm thread mounting pieces, but also a coned rubber thingy.
https://www.biltema.no/en-no/car---mc/workshop-equipment/test-instruments/compression-testers/compression-tester-2000016979
The other has more stuff
https://www.biltema.no/en-no/car---mc/workshop-equipment/test-instruments/compression-testers/compression-tester-petrol-2000022140
Re: Which compression tester should I get?
September 24, 2023, 03:22:13 AM »
If the cheaper one has the threaded adapters, it will be fine. It doesn't show any in the photos.
The rubber cones work, but can be a PITA.
S2R 800 '07
September 24, 2023, 03:39:42 AM »
Quote from: ducpainter on September 24, 2023, 03:22:13 AM
The cheaper one has a 14mm adapter. Our plugs are 12, I believe. Rubber PITA because?
September 24, 2023, 03:45:01 AM »
Quote from: stopintime on September 24, 2023, 03:39:42 AM
Sometimes it's a pain to hold it in place and operate the starter switch.
S2R 800 '07
September 24, 2023, 11:40:00 PM »
For a more specific piston to cylinder test, they recommend pouring a teaspoon of oil in the spark plug hole. That should spread out nicely in the vertical combustion chamber, but what about the horizontal? Spray another liquid in the hole? WD40? Silicone spray? Chain lube?
September 25, 2023, 04:17:44 AM »
Quote from: stopintime on September 24, 2023, 11:40:00 PM
Good question. My best guess would be fogging oil.
https://www.bing.com/shop/productpage?q=engine+fogging+oil&filters=scenario%3a%2217%22+gType%3a%2212%22+gId%3a%22156673970157%22+gIdHash%3a%220%22+gGlobalOfferIds%3a%22156673970157%22+AucContextGuid%3a%220%22+GroupEntityId%3a%22156673970157%22+NonSponsoredOffer%3a%22True%22&productpage=true&FORM=SHPPDP&browse=true
A more conclusive test would be a cylinder leak down test.
The tool is awfully expensive for a one time use, but any competent local shop should be able to perform this test.
S2R 800 '07
September 25, 2023, 12:33:30 PM »
Adapter is fitted finger tight?
September 25, 2023, 12:50:59 PM »
Quote from: stopintime on September 25, 2023, 12:33:30 PM
Yes. The o-ring should seal it.
