Ducati Monster s2r 1000 instrument cluster
Started by Pleh, June 21, 2024, 12:59:23 AM
Pleh
Hi guys,
I know there have been some situations where the instrument cluster, due to moisture, starts creating problems with turn signals. I am facing this issue at the moment.
I am interested to know if anyone has been able to repair it/fix the issue. Or at least does anyone have an el. scheme of the instrument cluster so that I can figure out where this turn signal "relay" is.
thanks.
Ducati Monster s2r800 & s2r1000
The electric chart is in a workshop manual. Have one? Find and download one? IIRC it's also in the owner's manual.
Member suzyj described that area of the instruments in detail, with pictures, while showing which "relay" it is that controls the fast flashing (when a bulb is blown). Find her profile in "members" and browse her posts. It's worth the time.
[thumbsup]
Pleh
Quote from: stopintime on June 21, 2024, 02:02:03 AM
[thumbsup]
very helpful, thank you :)
Pleh
[thumbsup]
I see that her instrument cluster is Digitech, mine is Magneti Marelli ... she seems inactive on the forum but I sent her private message anyway.
suzyj
I'm not familiar with the Magneti Marelli one. I would guess everything's done with one microcontroller. I'd be looking for eaten circuit traces for starters.
Pleh
Quote from: suzyj on June 23, 2024, 03:11:30 AM
Hi suzy, thanks for your reply.
I was cleaning the board with contact spray, there were some small traces of something like "rust", I am thinking now to try and clean it in an ultrasonic cleaner, to see if it helps.
I have Digitech and Magneti Marelli at the table; they are two completely different boards. I am not an electronic expert, so I was just trying to find the logic and some similarities, nothing.
How were you able to figure out turn signal driver on Digitech?
suzyj
I traced the circuit from the connector to the driver chip with a multimeter.
I looked the driver chip up, and found it was an Infineon BTS711L1. After reading the datasheet, I figured I could disable the open circuit sense by cutting the status pins.
Pleh
Quote from: suzyj on June 24, 2024, 09:04:06 PM
I believe that is too advanced for me :D
I was looking at both boards and on Magneti Marelli I wasn't able to find anything that even looks like the driver that you showed in your photos.
suzyj
Pleh
Quote from: suzyj on June 25, 2024, 06:47:50 PM
Can ya share photos?
I will disassemble it later and send you photo if this one is not good enough.
suzyj
At a guess, the powerSO-10 chip is responsible for driving the indicators. I'd be probing either side of that. I can't read the part number, but it could be something like this:
Pleh
Quote from: suzyj on June 26, 2024, 04:32:37 AM
I will disassemble later and send more detailed photos ... thank you soo much for the effort to help
Pleh
#13
here is a better photo
on chip it says:
VND05B
SP
31R322
ST MRO
EDIT:
I found this link
https://www.alldatasheet.com/view.jsp?Searchword=VND058
Pleh
I ordered this one
https://www.ebay.com/itm/123541112926
I will replace mine on the instrument cluster, I believe it is damaged by moisture. If you could tell me which "arms" to cut to prevent fast blinking, it would be great...thanks
