Welcome
![waytogo](https://ducatimonsterforum.org/Smileys/classic/waytogo.gif)
The pistons might be the same or at least useable, but as likely (for me, anyway) not. Different parts numbers has to mean something. If you're lucky it's better compression, but maybe the dome is wrong. Specialist stuff
![Huh?](https://ducatimonsterforum.org/Smileys/classic/huh.gif)
This bike will give you surprises - a couple of "hmm, not that bad" and several "make the beast with two backs, that too". Tires, belts, fluids, carbs, filters, chain, bearings, seals, rusty tank, electric stuff, inside engine (!?!?). The list IS longer.
Make a dedicated thread in Accessories & Mods. Learn how to post pictures. I use Postimages which is fairly easy (make several albums from the start. Avoid chaos later)
See you later
![coffee](https://ducatimonsterforum.org/Smileys/classic/coffee.gif)
