Misano fork cartidge home install?
Started by Privateer, September 22, 2024, 05:36:08 PM
Privateer
You might be fine doing it, but I would suggest using a good suspension shop. You order them yet?
Privateer
Quote from: koko64 on September 23, 2024, 12:47:08 AM
No, I was hoping for someone to talk me out of it, or talk me into something that wasn't $600 for a 20 year old bike.
it seems like it's just dismantling the old 'guts' and replacing the guts with the new cartidges.  But I'm afraid I'll get 1/3 of the way through, get stuck, and then be even deeper in it.
I would discuss options for your forks with a suspension shop. Some shops can graft on parts from other models or makes to get the job done that might give a better bang for buck. They can transplant and modify other valves and play with shim stacks to get a major improvement. Then you can measure the bang for buck ratio.
Quote from: koko64 on September 24, 2024, 04:54:20 AM
Yes!
MonsterHPD
On some Misano kits you have to separate the fork foot from one of the legs, and on some you don't. Helped a friend to install a kit on r
his Scrambler 800, had to on that one.
If you don't have to, it should be possible to do "at home".
Check with the dealer which sort this is.
