January 09, 2025, 07:51:40 PM *
News: Please Help
Pages: 1 2 3 [4] 5   Go Down
Author Topic: SS Bolts = THE BOMB  (Read 12294 times)
Capo
You Are What You Is
« Reply #45 on: July 31, 2008, 01:51:49 PM »
OEM Ducati bolts are made from cheese  Grin
Capo de tuti capi
« Reply #46 on: July 31, 2008, 01:57:00 PM »
What kind?
Capo
You Are What You Is
« Reply #47 on: July 31, 2008, 03:15:41 PM »
What kind?
Monsterella  Grin
Capo de tuti capi
« Reply #48 on: July 31, 2008, 05:15:15 PM »
 laughingdp applause
uclabiker06
"The time you enjoy wasting isn't wasted"
« Reply #49 on: July 31, 2008, 09:26:31 PM »
  laughingdp You set him up real nice for that one.
2006 S2R
2009 Smart
duckb0y
2005 S2R Dark
« Reply #50 on: August 01, 2008, 08:50:33 PM »
FYI from the engineering standpoint:
Stainless steel bolts: Not really all that much stronger than good grade 8 bolts. But a whole lot more expensive. Tits on a bull as well.
This is false, stainless bolts are at MOST on par with a grade 2 bolt.  Stainless hardware is hard and brittle, and will break before it stretches much.
For $50 you can touch my
« Reply #51 on: August 03, 2008, 08:05:46 PM »
Potato po-tah-toe.
Of the SAE Grades, Grade 8 is the strongest, with a tensile strength of 150,000 psi.
ARP supplies stainless bolts with tensile strengths in the neighbor-hood of 170,000 psi, and climb their way up from there.
Both 302 and 316 stainless have a tensile strength of 100,000 psi and yield strength of 65,000 psi, so if you want to call out cheap stainless sure, but in terms of the quality stuff, it *is* better fastener-which would be why those of us who work in aerospace will substitute it when titanium isn't available.
It's just excessive on a bike.
Capo
You Are What You Is
« Reply #52 on: August 04, 2008, 01:05:03 AM »
There was a thread on TOB, raising concerns that SS fasteners are subject to a form of embrittlement when exposed to any form of sodium chloride.
Capo de tuti capi
dlearl476
« Reply #53 on: August 04, 2008, 01:34:50 PM »
There are *infinitely* more useful things to address before the weight of your bolts.
+1
Their relative strengths, for one.
IMO, SS and Al are great for minimal stress, cosmetic uses.  Brake Rotors, not so much.  On a race bike where ounces count (and the bolts get changed every time the rotors do) sure.  A street bike.  No way.
And fwiw, Ducati uses locktite to put them on.  A heat gun and a gentle tap or two with the butt of your ratchet and they'll come right off.
Online Online
« Reply #54 on: August 04, 2008, 01:46:34 PM »
I would only worry about it if I were building a nuclear plant  that needs to last for a few hundred years.
« Reply #55 on: August 04, 2008, 02:04:08 PM »
+1
SS is great for minimal stress? Steel itself is a very high tensile meta. its not THE best, but i certianly would not put it in the same basket as aluminum. There are also many types of stainless steel used for varying applications from surgical tools to building sky scrapers. The stock bolts on the Ducati Rotors are also steel. I would not run aluminum on rotors, i dont see why running SS would be bad.
And as far as the rotors going, generally speaking a heat gun and a tap will work, but if its an outdoors bike with the elements attacking it 24/7. SS is the best metal to use for a reasonable price IMHO. I just looked at my rear rotors and theres also a salt film that has built up around the screw, screw head, and the rotor. All the bolts on my engine are the same.
TAftonomos
is without a monster :(
« Reply #56 on: November 03, 2008, 07:50:49 PM »
Oh crap, I just wasted more money on the bike with more Ti fasteners Cheesy
heel guard mounts (for my homemade heel guards
rad guard mounts (for my homemade rad guards)
Rear rotor mount bolts (for the lightweight rotor that is coming)
Front rotor bolts (just because I felt like it)
Front caliper mounting bolts (because the stock ones are huge)
Rear caliper mounting bolt (because I'm back there)
Rear caliper half joining bolt (because I like to waste money...otherwise I'd spend it on a big mac and get fat)
Swingarm brake line mounting thingy bolts (because the stock ones are twice as long as they should be, and again, why not?)
A whopping $100 on all of the above.   About 1/2 lb of rotating weight on the front, 1 1/2 lb of unsprung weight.
With the 520 chain thats laying around, and the quick change rear, along with the rear rotor, I might save ~3lbs of rotating weight on the rear end of the bike.
One day I'll buy some BST's  waytogo drink
jesse370
« Reply #57 on: November 03, 2008, 07:56:51 PM »
OOOOOOOOR a slipper.....
I took 6 lbs of rotating mass off the crank... Evil
I swear one day I will buy your Ti bolt kit
White S4Rs | Ducati Performance Chip | Termi's | Hyperpro side mount damper | Motowheels MW-7000 Slipper | Billet Clutch Cover |  Speedymoto Ti Spring Caps | Speedymoto Stainless Springs | STM Frame Plugs | Ducati Performance Seat | CRG Roll-A-Clicks
TAftonomos
« Reply #58 on: November 03, 2008, 07:59:39 PM »
6 lbs off the crank?
What clutch did you have before?
What bike is it?
jesse370
« Reply #59 on: November 03, 2008, 08:56:34 PM »
I have a S4Rs......my bad it was 5lbs....and I felt the stocker after it came out and the one that went in....HUGE difference
Pages: 1 2 3 [4] 5   Go Up
