January 09, 2025, 08:02:42 PM *
Pages: 1 ... 3 4 [5]   Go Down
Author Topic: SS Bolts = THE BOMB  (Read 12296 times)
Capo
You Are What You Is
« Reply #60 on: November 04, 2008, 01:29:56 AM »
OOOOOOOOR a slipper.....
I took 6 lbs of rotating mass off the crank... Evil
That would be the countershaft not the crankshaft.
Capo de tuti capi
madalf71
relaxing at home
« Reply #61 on: November 04, 2008, 03:04:10 AM »
Hi All.
Capo Re-Sodium Chloride.
Chlorine and 304/306 don't go well, and will degrade rapidly at temps above 50DegC.
My 2 cents worth.
Cheers all
Madalf
DucHead
No garage queens
« Reply #62 on: November 04, 2008, 06:36:39 AM »
Hi All.
My 2 cents worth.
Cheers all
Madalf
There's a big difference between chlorine and chloride.  Which do you mean?
madalf71
relaxing at home
« Reply #63 on: November 04, 2008, 03:44:09 PM »
Opps, should of been Chlorides.
Privateer
« Reply #64 on: January 23, 2009, 07:32:56 AM »
sorry to dig up a kind of old thread...
I've been replacing my hardware with the SS kits from monsterparts.. Is there a guideline for which bolts should get ant seize?
Handlebar clamp is the one I'm mostly wondering about right now.
Engine covers?
Thanks
Andy
Capo
You Are What You Is
« Reply #65 on: January 23, 2009, 10:30:14 AM »
Apply antisieze to all bolts except those that need loctite (such as the rotor bolts).
Antisieze does not dry out over time and allow the fatenerto sieze as stated by He Man.
Capo de tuti capi
Gimpy
Not quite a
« Reply #66 on: January 23, 2009, 06:45:34 PM »
This is what I do.  But.............. I would say that the only time that you need anti seize is when you are putting SS hardware into a dissimilar metal. (AKA Aluminum)
Capo
You Are What You Is
« Reply #67 on: January 23, 2009, 11:57:19 PM »
The use of antisieze on dissimilar metals, it primarily to prevent galvanic corrosion.
Where the metals are the same especially with stainless steel, the antisieze prevents galling.
Capo de tuti capi
Pages: 1 ... 3 4 [5]   Go Up
