Motorcycle transponder key replacement
Started by William Brown, May 21, 2025, 02:47:47 PM
William Brown
Hello my name is Jill I just purchased a used 06 monster 1000 without keys I am having the hardest time trying to get new keys and programmed so far it looks like e bay is my best course does anyone have any experience in this1
GreasySnipe
Hi Jill and welcome.
 I'm sure there are a few here that have done this, I've done this on a few except my 2010 Streetfighter frame-up build which has a PIC chip and not an Eeprom chip. I think the 2006 has an Eeprom 24C02 chip in the dash which can be interfaced with a CH341 kit (obtainable through amazon cheap), SOIC8 connector and a laptop with the right driver installed- you can get the Eeprom dump from a hex editor. you would need to look for the last lines in the dump that repeated themselves 3 times and the Immo code would also be in Binary and need a quick conversion to see the code(there are several online guides for this btw). If you are not too familiar with this, There are some services out there that will do this for you but do cost a bit of coin such as  SOS Diagnostics.
2011 Monster 796
2012 Street Fighter
2013 848 Evo
2016 Monster 821
2022 Scrambler Nightshift
2023 Triumph Speed Triple 1200 RS
2023 Monster 937 SP
DuciD03
FYI - Your posting in the wrong area, please derby in the right spot on DMF or it might get deleted or moved if your lucky.
s2r 1Ks are very nice bikes; odd you bought it without keys; I hope it isn't hot.
 [Dolph]
.... all the world is yours.
