December 27, 2024, 03:43:58 AM *
Pages: [1] 2   Go Down
Author Topic: DMF Painters/Detailers... Need help!  (Read 7597 times)
Timmy Tucker
Banninated
« on: May 07, 2008, 03:51:34 PM »
I just put my 95 Cherokee back on the road after 5 years in storage. The last 2 years it has been sitting uncovered under a row of pine trees  Cry and it is, not surprisingly, coated in sap. I've tried gasoline, kerosene and Turtle Wax Bug/Sap remover. None of those even worked. Dad said to use Isopropyl (rubbing) alcohol and it worked pretty good on the glass, but I'm kinda scared to try it on the paint. Will it screw up my paint if I use it there?
Is there anything that works better? You can see in the pics that I have a lot of work to do. These pics are with the jeep freshly washed, everything you see is sap.
These pics make baby Jesus cry:
1999 M750 - "Piggy"
2007 S4RS
For $50 you can touch my
« Reply #1 on: May 07, 2008, 05:28:07 PM »
It's a Jeep.
Go cover it in mud  Grin
Timmy Tucker
Banninated
« Reply #2 on: May 07, 2008, 05:52:51 PM »
It's a Jeep.
I would, but the transfer case is shot.
1999 M750 - "Piggy"
2007 S4RS
Mad Duc
Just because it is wrinkled doesn't mean you should call it a
« Reply #3 on: May 07, 2008, 06:09:19 PM »
Don't do it.
http://www.ehow.com/how_2002186_remove-tree-sap.html
http://answers.google.com/answers/threadview?id=739730
If it discolors the plastic on the fenders don't worry. Remove the fenders and paint the fenders with a black plastic paint. One can will do all the fenders and they will look brand new. Less than $5.
PA's official Ducati Owner's Club: PennDesmo.org
« Reply #4 on: May 07, 2008, 06:18:09 PM »
I'd try ice.
Just like on gum.
« Reply #5 on: May 07, 2008, 08:29:41 PM »
First try Acetone, then try MEK. Problem is the paint on that vehicle is thin and fragile at best.
Be careful with the MEK.
lawbreaker
« Reply #6 on: May 07, 2008, 09:19:58 PM »
Sap?. It looks more like a pigeon declared war ;:|
« Reply #7 on: May 07, 2008, 09:49:22 PM »
Oh yeah, I almost forgot about a clay bar.
Timmy Tucker
Banninated
« Reply #8 on: May 08, 2008, 06:01:18 AM »
I read about that somewhere else. Is that something I can get at Autozone or Advance, or do I need to go to a paint/body supply shop to get one?
1999 M750 - "Piggy"
2007 S4RS
« Reply #9 on: May 08, 2008, 06:32:06 AM »
I think so...
I buy from PBE places...
don't like the ice idea eh?   Grin
Timmy Tucker
Banninated
« Reply #10 on: May 08, 2008, 06:54:51 AM »
Ice would do the trick if the sap was still gummy. At this point, the sap is dried up and hard as a rock.
1999 M750 - "Piggy"
2007 S4RS
« Reply #11 on: May 08, 2008, 07:12:24 AM »
In deference to my learned colleague...  Wink
I'd try something a bit milder first.
Prep-sol or a wax and grease remover that definitely won't wash the paint off.
cyrus buelton
aka JuddDDDdd
« Reply #12 on: May 08, 2008, 07:13:32 AM »
pour boiling water on it
1999 M750 (joint ownership)
2004 S4r (mineeee)
SKOM
Upside Down Canuck
« Reply #13 on: May 08, 2008, 07:36:22 AM »
I worked at a detail shop for a couple years. We used Methyl Hydrate.
Not sure where you would get it.
Didn't hurt the paint at all. Spray it on with a bottle. Let it sit for 20 secs. The sap dissolves. Wipe. Repeat as necessary.
I think methyl hydrate is used in some lock de-icers.
Hope this helps  wt:
"Die gefährlichste Weltanschauung ist die Weltanschauung derer, die die Welt nie angeschaut haben."
— Alexander Von Humboldt
c_rex
Quick! Into the transmogrifier!
« Reply #14 on: May 08, 2008, 01:08:34 PM »
I'd... well I'd listen to Nate
definitely try the mild approach before anything chemical.
Pages: [1] 2   Go Up
