January 01, 2025, 07:38:56 AM
Please Help
Opinions on dry clutch choices
Topic: Opinions on dry clutch choices (Read 2906 times)
Porsche Monkey
JuddDdd likes my
The DMFer formerly known as Ducaholic
July 31, 2008, 09:08:27 AM »
My clutch is on the way out. I am looking at replacing it with a quieter setup that also adds some bling. I am looking at the STM 48 tooth setup and the Motowheels billet basket and plate kit. What are y'all's experiences with these?
http://www.motowheels.com/italian/myproducts.cfm?parentcategoryid=442%7CDucati&productID=1566&showDetail=1&categoryID=742
|Clutch%20Kits%3A%20Ducati&vendoridtodisplay=0&filterFor=&collection=165%7CClutch
http://www.motowheels.com/italian/myproducts.cfm?parentcategoryid=442%7CDucati&productID=4911&showDetail=1&categoryID=742
Quote from: bobspapa on July 18, 2009, 03:40:31 PM
Omnipotent Potentate
Personal Pretext
Re: Opinions on dry clutch choices
July 31, 2008, 09:21:08 AM »
There's the ProCutting option too
http://www.desmotimes.com/clutch_products.htm
- Row 1, Items 1 and 2
Alex
2000 M900ie
July 31, 2008, 10:34:21 AM »
I can attest to the procutting pack being very quiet. I had one that I wore through completely and even when the friction material was gone it was still quieter than stock.
However, I do believe that Barnett friction material is more prone to corrosion than others, so you might not want to go that route if you plan to park your open-clutched bike in the rain a lot.
Aftermarket: RoadRacing modified under-engine exhaust, revalved 996 forks, ProCutting half-open clutch, CC triple and pressure plate, 999 clipons, BMC filter, CRG-LS mirrors, PC3, Rizoma rearsets, heated grips, +2 teeth in rear gearing, Veypor VR2 computer, MBP collets, Yoyodyne slave, Galfer waves front and rear, misc CF (mostly faded), CRG clutch/brake levers.
numbskull
'07 S2R1000
July 31, 2008, 10:42:49 AM »
Quote from: yuu on July 31, 2008, 09:21:08 AM
+1 on this option. I just installed this two weeks ago and it was big improvement. It's noticeably quieter than my previous stock set-up.
Porsche Monkey
JuddDdd likes my
August 01, 2008, 08:06:16 AM »
Anyone else? I'm probably gonna end up changing the basket while I'm at it.
Fresh Pants
Moof
August 01, 2008, 08:12:43 AM »
I replaced my worn out stock clutch with the pro cutting basket+barnett plates from Desmotimes.
Lost about 2.6 pounds in the process, engine feels like it spins up faster, and engagement was much better than my old clutch (granted my old clutch was pretty worn out). And it's almost as quiet as a wet clutch bike, which is both good and bad (bad because I sort of miss the JINGLE JINGLE).
Bwooooooahhh
Braaaaaaaappp
Juan
August 01, 2008, 10:53:23 AM »
I have the motowheels slipper clutch. I am liking it a lot
http://www.rcgroups.com/forums/customavatars/avatar275629_2.gif
[/img]
bfoster
2006 Monster S4R
August 02, 2008, 04:17:39 AM »
Quote from: Juan on August 01, 2008, 10:53:23 AM
Once my bank account recovers from my latest string of upgrades I was thinking of getting a slipper clutch / fancy cutout cover. I was just curious how the the cutout covers work with moisture... is there any danger of getting too much water in the clutch? I try not to ride through giant puddles or in extreme downpours, but this is South Florida and sometimes it just happens without much advance notice.
S4ROB
August 02, 2008, 05:43:09 AM »
How much noise does it make? I like the look, but I want the music. That’s right, music, not noise.
"Guns. You think you have enough, until the ZOMBIES come."
Gunslinger's Journal
2001cromo
August 04, 2008, 10:42:10 AM »
If I were getting a slipper, I'd get the Surflex from Motowheels.
it's quite and it's got a light pull and best of all it's a LOT less maintenance.
http://tinyurl.com/6k2nv8
Juan
August 04, 2008, 11:22:10 AM »
I have no problem with moisture or water for that matter. Here in the bay area, we don’t get much rain. However, I should say, that I ride my bikes in the rain and I have not seen any problems with the clutch so far.
The noise level is less than the stock clutch. I have to say however that if you have a monster that is 2002 or older, it may stop singing and may only make noise. Unfortunately and this is only my belief, Ducati change something on the clutch later on that newer bikes just make noise and not music. the 900s, 749, and the 916/ 996 and 998 really sound sweet. IMO.
My bike is a 2005 M1000, what can I say, I really don’t like the sound of my clutch as much as that of the other bikes I stated before.
Ride safe.
[/img]
Capo
You Are What You Is
August 04, 2008, 12:56:32 PM »
If you can spring for a slipper do it. By far the best mod I've made.
Capo de tuti capi
