Any ideas what to do with those ugly holes once you take your bars off?
Started by SaltLick, July 31, 2008, 02:21:39 PM
SaltLick
i put clipons on, now i got those 4 ugly holes where the old bars use to mount. Grinding all that down is not an option....what are people using to cover that up with?
SaltLick
first one is a GPS? Second one looks great, but my hole pattern is like the first one.  Man keep the ideas coming!  I am one of those wierdos that straightens pictures on the wall, all i do is look down at those 4 holes and dream of stuff to cover it up with.  I went down to home depot and another hardware store and looked for some sort of caps to put over them, nothing looked good. Then i thought of putting a metal plate across it, cutting a cool pattern into the plate, but i dont really have a way to cut metal precisely enough to make it look good. Is there a business that would cut or lazer cut a pattern into a piece of metal for you? i tried to look it up locally here in portland but came up with nothing.
herm
buy 4 allen head metric bolts (whatever the correct diameter)
paint them to match your tank
insert into riser holes
done
Quote from: herm on July 31, 2008, 03:00:23 PM
done
+1
Mother
Quote from: 696Racer on July 31, 2008, 06:10:40 PM
Sittin on your handlebars or cupcake, nobody is gonna be noticing your holes no more.
<edited>
dewd  [roll]
take the compilation down
this is about motorcycles and not your personal fetish
zvezdah1
Should be able to get the black plastic caps/plugs that are basically flat and smooth, can get them at auto parts store, just a dab of silicone in the hole and works fine been using for years when I've take off mirrors, changed the pipe mounting, etc.
Chris
spinned
Quote from: someguy on August 01, 2008, 09:34:23 AM
Let the holes fill with dirt.
Paint over it.
Fill with Bondo, Then Paint over it, like on Spidey's Bike.
