February 01, 2025, 11:02:27 AM *
Author Topic: when all else fails.go back to step one.  (Read 1711 times)
pigmy
« on: August 03, 2008, 03:05:50 AM »
ok,so i get back from overseas.try to start bike flat battery.no probs.buy a new one and hay presto no start.
so i  charge battery and no start.ok check all connections, wires and anything with electrons.off comes starter
on goes another relay and presto no start.so off comes starter again off comes battery and down to local
electrician to physically load test parts and nil defects found.so on go parts again.still no start.weeks go by
friends give help/advice (thanks mmick,ducmon rob).then i decide to get serious so i jump start the bike
off the car and we have start.hmmm theres a hint here.back to the local shop receipt in hand.off to another local
shop and another( better) battery later.houston we have ignition......moral of the story.dynomaster batteries are
sh1t.
loony888
"I WAS GOING HOW FAST, OFFICER?"
« Reply #1 on: August 03, 2008, 03:29:05 AM »
there's plenty of garbage out there, i only use yuasa.
paul.
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
dragonworld.
I can make like a tripod with my.....
« Reply #2 on: August 03, 2008, 05:34:39 PM »
When I was initially looking for a Monster to purchase I looked at a 900 that a guy had tricked up a bit and he was running a battery out of a Skidoo/snow mobile. It had a shitload of cranking power and he'd never had a problem with charging. (He said??) Dunno what brand it was though. Being designed to supply current and amps in very cold weather you would think it would be operating easily at "normal" temps. Hmmmmmmmmm.Huh?? Wink
brimo
酒後吐真言
« Reply #3 on: August 03, 2008, 07:26:56 PM »
Yep it would work well at normal temps but also would probably be better built internally as well to stand up to the physical pounding it would get. Boat batteries are the same.
It's worth purchasing a cheapo multimeter for those "dead battery" times, you can see if the batteries dead or your charging system is working ok. Saves $$$ in the long run.
If anybody needs assistance or has questions,in this, I can help, (I'm an electrical\electronics dude)
From a story by RAT900
monstermick58
« Reply #4 on: August 03, 2008, 10:44:10 PM »
Finally pigmy,
                    So tell us what happened to the plastic spacer off the end of the starter motor??
I think my next battery will be a Deka
                                                   Mmick
pigmy
« Reply #5 on: August 04, 2008, 02:46:38 AM »
mick,that spacer was a gasket.i had to put it back on.boy im getting good at doing starter motors now laughingdp
bazz20
« Reply #6 on: August 04, 2008, 03:04:55 AM »
sounds like you need to get a trical , mainternace charger and leave it on
DUCMONROB
Geez its getting hot holding my
Nothing like the sound of a Ducati!
« Reply #7 on: August 04, 2008, 04:28:07 AM »
Pigmy great to hear you sorted out your starting problems.
The starting circuit is very basic so when you changed/ checked everything else it just had to be..........
See you on the road soon mate.
Rob [moto]
M1000SDS, ZZR1200, GPZ900R.
Gone:
900 Monster Special
S2R1000
998 Matrix
