Got my bike back....
Started by HeyThatsMyBike, August 03, 2008, 11:51:48 PM
HeyThatsMyBike
So finally after 2 weeks I got my bike back from the dealer... It got backed into and luckily everything was covered by the other persons insurance.  I was able to put CRG levers on it... My first mod!!  The side stand assy. was one of the parts that was replaced, and I just realized that I can't start my bike without putting it in neutral. With the side stand up, in first gear and clutch pulled in it won't fire.  Does that indicate a fault in the wiring? Something the dealer needs to fix again?! What do you all think? Thanks in advance!
Flying low ;)
'08 695 Dark
Look on your clutch side, look at the point where the lever's joint. now look underneath it. there shouldd be a little switch to your left, towards the bike. That button needs to be clicked pressed for the bike to start in gear with the lever pulled in. CRGs should have a little tab on the lever to press that switch when you hold the lever. Or if there is a tab, you might be missing the little nub. You know wht im tlaking about when you see it
HeyThatsMyBike
Thanks Man! Just looked and the tabs not there!  I saw the little switch that gets pushed in.  The dealer didn't even let me know!  Going to email them right now!  Thanks for the info...
Flying low ;)
'08 695 Dark
CRGs are the ones that dont have that piece. There might be a second piece you can buy to attatch, otherwise your SOL. I think only Pazzo and ASV levers have this piece built in, as well as rizoma and Motowheels brand.
HeyThatsMyBike
Found one at Monster parts for 15 bucks.  I might just try and make one... For right now I'm just going to have to start in 'N' !!!  Should have gone with the Pazzo's... Oh well  [roll]
Flying low ;)
'08 695 Dark
Duc L'Smart
Glad you're back to (almost) 100% [thumbsup]
'07 1098s, '06 Paul Smart LE, '99 BMW K1200RS, '73 BMW R75/5, '67 Ducati Monza 250 Bevel Drive, '63 Vespa GS 160
ArguZ
Ha ! That's what it is for...I bailed out on using some cheap handles because I wasn't sure what the little switch was doing.
On the other hand I kinda like the idea of having a protection against starting it WITH the stand out...
