Securing the Front end off its suspension
Started by Kovner, May 07, 2008, 07:38:39 PM
rgramjet
I heard the same warnings.... rode carefully for the first 5 miles or so.  Once my comfort level was established, I had a grin that lasted about 2 days!
-Sofadriver
Kovner
Quote from: rgramjet on May 11, 2008, 06:08:27 PM
What bike do you have? How far did you raise the forks? What clipons do you have?
rgramjet
2001 M900 Cromo
Motowheels 50mm clip ons were flush with the top of the forks, they are 5/8".  Now Ive got Ferracci clip ons, they are 1-1/4" and  are flush with the top of the newly installed sbk forks.
-Sofadriver
Kovner
Alright, I  measured the Apex clip-ons and they're 28mm high.  So could I not raise the forks 28mm, put the clip-ons on top of them, then lower the rear end something like 18mm, giving me a net front-end decrease of 10mm?
I just looked and it appears that mine is already and the lowest setting possible. I'll have to see how well it handles on the way to work tomorrow...
rgramjet
Why are you adjusting the rear?  Mines jacked up all the way and Im looking for more!  Anybody know where I can get an extended heim joint?
-Sofadriver
Cause I lowered the front for the clipons...
rgramjet
Did you ride it before lowering the rear?  I get the concept, I just dont know what the rule of thumb is.  Mine is an m900 so I dont know how the adjustments differ between your bike and mine.
I had warnings about moving to a wider rear tire and about how even a 4mm drop in the front can adversely affect the handling.....I experimented and now Im happy.
-Sofadriver
Haven't ridden it yet. Tomorrow morning will be it's maiden voyage with the new bars...
Kovner
#24
Just to make sure, my 03 M800 Sie doesn't have a rear height adjuster, right?
So, to adjust the rear height, I have to adjust the rear preload with the locking rings?
Cider
Quote from: Kovner on May 12, 2008, 10:15:30 PM
The tie-rod is adjustable and can be used to adjust ride height.  Shock pre-load should be set to achieve a particular sag value.  Keep an eye out for chain/swingarm interference if you raise the rear end a bunch.
Kovner
Hrmm, searched around and can't find any info.
How do I adjust the tie-rod?  Can I get a quick pic of where the adjuster is?
