oil filter cross reference?
Started by meano_lover, August 04, 2008, 11:23:54 AM
meano_lover
hi all, i hit a rock yesterday that put a pinhole in my ducati oil filter, looking for a new one, but find it hard to pay 27 dollars at the dealer. is there a cross reference for oil filters? i know there's a post in the "Alternatives to expensive Ducati parts" forum here in tech for fuel filters, but oil filters maybe? any help is appreciated. thanks!
'97 m900; stage 2 carbs, filter pods, remus carbon exhaust
$27!?  wtf... my local dealer sells the DP filters for about half that.  For the price I can get them at it's a toss up between brands, regarding the price.
Other filters that will fit
K&N 153
Amsoil EaOM138c
Fresh Pants
And...
Hi-Flo Filtro HF 153 ~$7. (They supply a lot of OEM for filters, but are cheaper)
Bwooooooahhh
Braaaaaaaappp
Your dealer is pretty much doubling the price for the OEM filter.
Quote from: French Pants on August 04, 2008, 11:49:51 AM
And...
AFIAK, Ducati also.  Where are you buying them?
Fresh Pants
Quote from: howie on August 04, 2008, 02:39:17 PM
Local moto parts shop has 'em, but I bought a couple of the Amsoil EAO filters recently.
Bwooooooahhh
Braaaaaaaappp
depending on how often you change your oil, id just buy a few of them and throw them in the closet. They are only $12 bucks online.
VeryMetal
Quote from: He Man on August 04, 2008, 03:51:43 PM
+1 on this.
You're never going to regret buying a couple more than you need at the time, expecially if it saves you shipping.
I used to do this with oil for my R6, go to the dealer, get a bunch of filters and 'no name' oil right out of the barrel (same as a certain AHEM 'branded' oil on the shelf) and I'm set for about 4 or 5 oil changes for the price of 2 or 3. Works out good in the long term. I'm probably going to be a lot fussier about the oil I put in my duc though.
2002 Ducati Monster 750ie Dark
2005 Monster S2R Dark
rockaduc
Quote from: meano_lover on August 04, 2008, 11:23:54 AM
I had the same thing happen to me 3 weeks ago.  Luckily I didn't crash...sounds like you didn't either which is good.  K & N oil filters are pretty cheap online...about $15.00.
mmakay
Here is the most complete list I could find.  I last used the NAPA filter, and at that time it was made by Mann of Germany.  Excellent quality for about $7.
US available: (exact)
  K & N KN-153
  Perf-Form DUC-1
  Athena FFP011 (Ducati OEM)
  Scott's Performance (permanent washable replacement)
US available: (near exact, fits fine.  length may vary)
Fram PH6074 (was PH2839, PH2864A)
  Purolator ML16829C (was FC 103 or OC 5)
  AC Delco FX0011 (was X4A)
  Motorcraft EFL 47
  NAPA: 1352 (1352NAPA and 551352 on the box)
Non US:
  Champion H101
  Cooper Z64
  Powertrain FL125
  Fiaam FT4654, FT 4847 or PA7059
  Purflux LS187
  Halfords HOF216
  Tecafilter Ref OC5
  Technocar R12, R72, R434
  Knecht OC 5 (equivalent to Ducati #065149960 and #090549960)
  TJ FB2094
  Mann & H W712/9, W712/11
  Unipart GFE 201
- Mickey
meano_lover
thanks everybody! i went down to my local cycle gear and they had a k&n for about 14. so i swooped up the last 3 they had in stock. i'm not so pleased with my local duc dealer.
mmakay- sweet list, maybe post it to the stickied topic above?
MotoPsycho
Good cross reference list I ran across a long time ago - glad I kept it now.
Motorcraft EFL 47
Champion H101
Cooper Z64
Powertrain FL125
Purflux LS187
Halfords HOF216
Tecafilter Ref OC5
K & N KN-153
Knecht OC 5 (equivalent to Ducati #065149960 and #090549960)   TJ FB2094
Unipart GFE 201
Desmo Demon
I switched to using the K&N simply for the welded nut on the end of it. It makes removal sooooo easy.
Here's an interesting tidbit......if you are in a crunch and on a trip somewhere and NEED a filter but cannot find one, go to the local Harley-Davidson dealer.......yes, the local Harley dealer......There are certain mid-80's Harleys that use similar filters. I use the K&N 153 on my '85 FXEF, also.
(So, if you want a chrome filter for your Duc, you can use K&N 172C)   [laugh]
The differences are that the KN-153 has a 1.45 psi higher pressure relief valve and is 0.209" (6mm) longer than the KN-172C. The KN-172C also does not have an anti drain back valve (so an OEM Harley filter should have similar specs to the KN-172C). The last time I bought a filter from the HD dealer, the black one was $5-$6. I think the old 100k+ mile engine can use the higher pressure that the KN-153 supplies, though
KN-153 specs...
Product Style: Oil Filters
Height: 3.331 in (85 mm)
Outside Diameter: 3.059 in (78 mm)
Thread Inside Diameter: M16 x 1.5
PSI Relief Valve: 15.08
Anti Drain Back Valve: Yes
Style: Canister
Weight: 0.7 lb (0.3 kg)
Product Box Length: 3.25 in (83 mm)
Product Box Width: 3.25 in (83 mm)
Product Box Height: 3.5 in (89 mm)
KN-172C specs...
Height: 3.122 in (79 mm)
PSI Relief Valve: 13.63
Anti Drain Back Valve: No
Style: Canister
Finish: Chrome
Weight: 0.6 lb (0.3 kg)
Product Box Height: 3.25 in (83 mm)
IBA #32735
