Maintenance List
Started by Mother, August 05, 2008, 04:33:49 PM
Quote from: JBubble on October 22, 2008, 07:10:29 PM
Let me have my delusions man!!!!
would you feel better if I grinned?    ;D
jdubbs32584
Quote from: ducpainter on October 22, 2008, 07:21:07 PM
Thanks. All better now.
krolik
 You're slippin' JBub, you let him off the leash long enough to post a reply. ;D
jdubbs32584
Quote from: krolik on October 22, 2008, 10:05:16 PM
Time to break out the whip again...
herm
next thing you know, mother is gonna move of the mountain, down to the midwest.........
maybe even ohio.
i feel dirty now.
going to go and bath in whiskey to cleanse myself.
No more Monster.
jdubbs32584
Quote from: herm on October 23, 2008, 07:17:46 PM
maybe even ohio.
i feel dirty now.
Oh, I'm not that bad!  [cheeky]
krolik
Quote from: JBubble on October 23, 2008, 07:32:32 PM
Yes you are.
Maybe we should call you "Vixen"
Wait, that names been taken. ;D
herm
No more Monster.
jdubbs32584
Quote from: krolik on October 23, 2008, 11:47:47 PM
Yes you are.
Oh both of you hush!  [cheeky]
He ain't doin nuthin he don't want to. Boy gets glued to the spot right quick and I sure as hell can't move him.
;D
ryandalling
Quote from: JBubble on October 24, 2008, 05:19:19 AM
You prolly shouldn't glue him to that spot then... might make it horribly difficult to put your unmentionables back on.  [evil]
Confused rider who doesn't know what he is even riding at the moment. (2012 URAL GearUp, 2012 Ninja 250 Racer, 1969 CB175 Racer)
GAAN
#70
Ignore this
I'm just putting it in a place I will remember
Needs:
Rear Strada-Done
Clutch
Gasket Set
Springs?
Un-integrate tailights-Done
Rear Signals-Done
POR-15 Marine Clean
Belts-Done
Chain-Adjusted
Sprockets 14/46-Checked
Crank case Breather Valve-Done
Oil-Done
Filter-Done
Valve Adjustment
Throttle Body Sync
Rear Wheel Bearings
Rear Brake Pads-Done
Rear Rotor-Checked
Front Pads-Checked
Front Rotors-Checked
Projects:
Chop Belt Covers-Done
Hide wires-Done
Cut Brackets and Mounts
Lower Guages-Done
Dyno Map PC-III
Wants:
Spare set tires Pilots or Stradas-Done
PTO Beast-R Pod filters
Rectifier Relocator
Crank Case Breather Filter
Galassetti OMOLOGATO slip ons
Ohlins Front-Done
Ohlins Rear
5 spoke marchesinis 5.5"
Oil Cooler S4R Style (low mount)
Dry Clutch Conversion
And real Paint - Done or as done as it's ever going to get
Betty Rage
Darkhorse den mother
krolik
#72
Quote from: Mother on June 21, 2010, 01:17:30 AM
Ignore this As if! [evil]
Needs:
Valve Adjustment You still haven't done your valves?!?! How many miles is it now 45K? :o
Projects:
Dyno Map PC-III
Wants:
TPO Beast-R Pod filters  Do the PCIII map after the pods, you're gonna need it anyway.
And real Paint What, the rattle can special ain't working for you? ;)
GAAN
42 ish
and it runs just fine...sorta
duc_fan
I skipped the 12k valve adjustment.  I used to claim that I was just late, but now I'm at 15k+... halfway between the 12k and 18k intervals.  I think the 12k adjustment now counts as officially "skipped".   :P  At least I replaced the belts, so I know those aren't dry and brittle.
