Maintenance List
Started by Mother, August 05, 2008, 04:33:49 PM
Mother
Ignore this
I'm just putting it in a place I will remember
Needs:
Rear Strada-Done
Clutch
Gasket Set
Springs?
Un-integrate tailights-Done
Rear Signals-Done
POR-15 Marine Clean
Belts-Adjusted
Chain-Adjusted
Sprockets 14/46-Checked
Crank case Breather Valve-Done
Oil
Filter
Valve Adjustment
Throttle Body Sync
Rear Wheel Bearings
Rear Brake Pads-Done
Rear Rotor-Checked
Front Pads-Checked
Front Rotors-Checked
Projects:
Chop Belt Covers-Done
Hide wires
Cut Brackets and Mounts
Lower Guages-Done
Dyno Map PC-III
Wants:
Spare set tires Pilots or Stradas
PTO Beast-R Pod filters
Rectifier Relocator
Crank Case Breather Filter
Galassetti OMOLOGATO slip ons
Ohlins Front
Ohlins Rear
5 spoke marchesinis 5.5"
Oil Cooler S4R Style (low mount)
Dry Clutch Conversion
And real Paint
NEIKOS
I might have an alternative for you to the TPO Beast and relocator kit.
Mother
Quote from: NEIKOS on August 05, 2008, 04:35:56 PM
Betty Rage
That looks a lot like a gift registry.  ;D
Darkhorse den mother
Visolara
I have a brand new Barnett Ducati clutch in my garage, complete with basket, plates, and pressure plate.
Make me an offer foo!
Maurice Miller
2009 OMRRA Rider Representative
OMRRA #39
WMRRA #39
Dark Horse Racing
Race Supporters -
Noel Communications, Inc. , 2Fast Motorcycle Track Days & Instruction , KBC Helmets , EDR Performance , Cascade Tracktime , GP Suspension North , KFG Dunlop LLC , LP Privateer , Dainese , AMS Oil
| 2006 Ducati 749S (street) | 2004 Suzuki SV650S (race) | 2002 Aprilia Mille (race) |
NEIKOS
Quote from: Mother on August 05, 2008, 04:53:26 PM
I didn't do the beast but I did do a pod kit install and rectifier relocation.  I could share my notes, etc.  It's a lot less expensive.
Visolara
Quote from: Visolara on August 06, 2008, 08:23:34 AM
I forgot you had one of those wet clutchy things.  My clutch no worky on your thing.
Maurice Miller
OMRRA #39
WMRRA #39
Dark Horse Racing
Race Supporters -
Mother
Quote from: Visolara on August 06, 2008, 11:19:24 AM
Unless I change it over to a dry clutch...
duc_fan
Hey Mo, that Barnett clutch pack... are those aluminum plates & basket, or the stock-replacement steel?  What about the pressure plate, is that any kind of blingy aftermarket one?
I'm looking for an excuse to mod the clutch on the SS... it's getting grabby (probably just needs cleaned and inspected...but I could use an excuse to mod it).
Mother
Quote from: BibleBoy on August 06, 2008, 02:01:21 PM
Hey!!!
you little vulture
go away
Mine
[cheeky]
ryandalling
Quote from: Mother on August 06, 2008, 02:09:08 PM
Hey!!!
you little vulture
go away
Mine
[cheeky]
I hear it is a serious pain in the ass to mod a wet clutch into a dry one... unless you just want to duct tape a tamborine to the side of your engine for the rattling noise. Let the bible vulture get his clutch.  [clap]
Confused rider who doesn't know what he is even riding at the moment. (2012 URAL GearUp, 2012 Ninja 250 Racer, 1969 CB175 Racer)
Mother
Fine
take it
but from now on you are The Vulture
;D
I don't have the money for the 996 gears anyway
duc_fan
Hey!!!
you little vulture
go away
Mine
[cheeky]
[laugh]
Last time I checked with Stu, it was around $1000 to change a wet clutch to a dry.  I just made the assumption (based on the original post) that it'd be pretty low on your priority list.  (I wouldn't have asked if I knew you had a dry clutch... not tryin' to steal parts out from under anybody)
So yeah... guess I am a vulture, swooping in on unneeded parts.  ;)
Mother
Yeah I talked with him about it
got about the same price
and an extensive parts list
but
I just don't see why it has to be that involved
I would think all you need is to change out the clutch-side cover from a 1000ds and get a dry clutch and you should be good
Visolara
its an aluminum clutch basket, and pressure plate for sure, I need to check on clutch plates, I would think they are steel (more durable for this purpose then aluminum) but will need to check when I get home.
I think the pressure plate is anodized red too.  :)
Maurice Miller
OMRRA #39
WMRRA #39
Dark Horse Racing
Race Supporters -
