Maintenance List
Started by Mother, August 05, 2008, 04:33:49 PM
herm
to recap
Ignore this
I'm just putting it in a place I will remember
Needs:
Rear Strada-Done
Clutch
Gasket Set
Springs?
vote for the governator
Un-integrate tailights-Done
Rear Signals-Done
POR-15 Marine Clean
Belts
Chain
Sprockets 14-46
spend the night with al gore
Crank case Breather Valve-Done
Oil
Filter
Valve Adjustment
Rear Wheel Bearings
Projects:
Hide wires
Cut Brackets and Mounts
Lower Guages-Done
lower alcohol intake
Dyno Map PC-III
Wants:
Spare set tires Pilots or Stradas
PTO Beast-R Pod filters
Rectifier Relocator
Crank Case Breather Filter
Galassetti OMOLOGATO slip ons
give herm the money instead
Ohlins Front
Ohlins Rear
5 spoke marchesinis 5.5"
Oil Cooler S4R Style (low mount)
And real Pants
......thats some list mom ;)
No more Monster.
jdubbs32584
 [laugh]
Yeah right on the 'lower alcohol intake'.  [roll]
And yes please on the 'real pants'  [thumbsup]
ryandalling
What about suspenders... everybody needs a pair of those.  [thumbsup]
Confused rider who doesn't know what he is even riding at the moment. (2012 URAL GearUp, 2012 Ninja 250 Racer, 1969 CB175 Racer)
bnbmike
Quote from: ryandalling on August 07, 2008, 08:26:54 AM
"Mork calling Orkin, come in Orkin."
Had 2001 Monster 750 Dark, last of the carbby's.
Has 2011 Multistrada 1200 ST
NEIKOS
Quote from: bnbmike on August 07, 2008, 09:01:16 AM
I used to have a pair or two of those!  [thumbsup]
jdubbs32584
NEIKOS
Quote from: JBubble on August 07, 2008, 09:43:58 AM
Is that Robin Williams?
OMFG!!!
What were you . . . like not born in the early 80s?  [cheeky]
Yes, Robin Williams during his coke induced funny days!  ;D
jdubbs32584
Quote from: NEIKOS on August 07, 2008, 09:47:55 AM
OMFG!!!
I didn't enter this world til 84 dear. Most of my early memories are from the 90s.  ;D
krolik
You didn't put "Get new vest" on that list?!?!
Sheesh!
;D
duc_fan
Quote from: JBubble on August 07, 2008, 10:00:20 AM
Wow... kids are invading the board.
I thought I was the young one at May of 1983. (though even I recognized Mork & Mindy ;))
jdubbs32584
Quote from: krolik on August 07, 2008, 11:58:48 AM
Sheesh!
;D
Haven't you noticed? He's moving away from that thing to button downs!!!!  :o
duc_fan
Hey Mom, the other thing I've heard about on wet-to-dry clutch conversions is the need for some kind of custom bushing for the output shaft.  And you'd probably want to use a 900 case, as the 1000ds case might be slightly different (clutch is the same, but I know the left-side case is different, and the right-side may be slightly different as well).
Quote from: Visolara on August 06, 2008, 03:39:33 PM
its an aluminum clutch basket, and pressure plate for sure, I need to check on clutch plates, I would think they are steel (more durable for this purpose then aluminum) but will need to check when I get home.
I think the pressure plate is anodized red too.  :)
Red anodized pressure plate would be bootiful!  My only concern on having steel plates in an aluminum basket is premature wear because of the dissimilar metals.  From what I can tell, one either wants aluminum-on-aluminum, or steel-on-steel.  However... the Barnett basket I saw on their website had steel inserts for wear purposes.  If that's the case then one has steel-on-steel wear surfaces, which would be fine.
Anyways... I'd definitely like to take a looksie at this clutch setup.  Then we'd need to determine the fair value and I need to see if I can afford it.
Mother
Quote from: BibleBoy on August 07, 2008, 12:29:02 PM
as I understood it, the 1000ds and the 620 are te same motor, just different pistons, heads,, and clutch
so a 1000ds right side cover should include what is needed
but who knows  ???
Mother
Mother
wow
it is amazing how much more responsive the motor is when the belts are adjusted correctly
