Removing stock mufflers?
Started by Dream, August 06, 2008, 12:19:33 PM
Dream
2005 S2R 800 all stock. Looking to make it sound better, but dont want to do the full exhaust setup until next summer. What I run into problems if I just removed the stock cans?
brimo
Do a search, here's one link
http://ducatimonsterforum.org/index.php?topic=7790.0
Thought about coring your existing cans?
Pretty easy.
From a story by RAT900
uclabiker06
If you remove them make sure to get ear plugs because hearing loss is both gradual and permanent.  You will also lean out the fuel/air mixture by doing this to you might get some popping.  To make up for that you will have to adjust your fuel/air by getting a trim adjustment at the dealership or even better getting a custom map on a PCIII.  Good luck.  And remember in terms of the overall "health" of your bike running too rich is always better than running to lean.  Lean can damage, rich cant.
2006 S2R
2009 Smart
herm
i ran my s2r1000 with only the udder for 1/2 of the 8500 miles on it.
no adjustments needed (per my local duc dealer)
of course, the 800 may be different....
+1 on the ear plugs. i found it to be too loud in the long run.
No more Monster.
