Rizoma Reservoir question
Started by Bbrent, August 07, 2008, 12:42:08 PM
Bbrent
Is it necessary to bleed the brakes and the cluch fluid when installing these or can you clamp it off at the tube swap reservoirs?
herm
No more Monster.
if your good enough to do it without introducing airbubbles then your fine. but if you have to ask....then yes bleed it.
scduc
Try it, You will know right away if you need to bleed. Even the smallest air bubble will make the lever feel flat and mushy.
Alexandre
just bleed it... its not THAT much work...
watch out for leakage after install,,, dont overfill
supertjeduc
I didn't bleed them last time i installed new ones ,air goes up so
corey
What type of brake fluid do our bikes take???
Bbrent
What do you guys recomend for brake and clutch fluid?
DarkStaR
Carman
What size resevoir are you using?  I checked out the Rizoma sight but wasn't sure.
Carman
'07 S4RS
Bbrent
I bought (2) 26 ml bottom outflow and (1) 27mm side outflow for the front brake. You may want to go even smaller on the rear brake because it's alittle tight down there. I haven't put them on yet. If your thinking of getting them go through PJ's Parts. They are very fast.
Carman
Quote from: Bbrent on August 08, 2008, 01:24:57 PM
Thanks for the info, anyone running anything different?
Carman
'07 S4RS
Carman
What size/volume are those?  to be honest I don't know what the stock volume is.  Look nice!
Carman
'07 S4RS
Bbrent
The mounting bracket that came with the Rizomas are straight. Did you have to ben yours to work?
