Any experience with these pressure plates?
Started by El Matador, August 08, 2008, 02:51:17 PM
Direct clone of the stock pressure plate. eh. if your going to spend your money on a new plate, spend it on something that has more protection. anything that covers the springs is better than leaving them exposed.
Magnus
huh?  it's a pressure plate, not a clutch cover.
'02 MS4 Black Fog
Quote from: Magnus on August 09, 2008, 09:12:43 AM
There are pressure plates out there that cove the springs...
moto
Quote from: NAKID on August 09, 2008, 10:55:40 AM
Yes--but from personal experience, The level of protection from a pressure plate is overated and more of a marketing point. They don't do as good a job as a billet clutch cover--and they are a bit heavier. Since it is a rotating part, I'd rather add the weight of a billet cover rather than the pressure plate for protection.
-M
www.motowheels.com
96 M944
98 900SS FE
01 996R
02 MV Agusta F4 750
05 999R
06 SC1000
07 1098
08 M696
A.duc.H.duc.
Quote from: moto on August 09, 2008, 03:40:21 PM
-M
Unless the whole point was to run without a cover at all.
Duc Fever
To answer the question asked. YES, I bought this pressure plate and it has been installed on my S2R1K. It is NOT a clone of the pressed aluminum stocker by any means. It is not as aggressively styled as some others but I like it. I found no flaws in the workmanship and the fit was perfect.  I paired it with the TPO racing spring set  and was very satisfied with the results.
http://ducatimonsterforum.org/index.php?topic=8719.0
"You have not converted a man because you have silenced him" ~ John Morely
El Matador
Quote from: Duc Fever on August 09, 2008, 11:10:34 PM
Awesomeness! Thanks everyone!
Magnus
Quote from: A.duc.H.duc. on August 09, 2008, 04:41:00 PM
if the bike lands on the clutch, is a pressure plate with some protection for the springs really going to save anything?
'02 MS4 Black Fog
yes. you know those posts that the screws go into? inmagine those snapped of (they are connected all the way into your engine).
