Ride Height
Started by Bbrent, August 10, 2008, 01:44:40 AM
Bbrent
I'm planning on adjusting the ride height on my S4RS. I know this is going to be a pain from everything I have read. Am I going to have to take the whole rod out?
After what I heard, it works like the gear shaft connection - one clockwise and one counter. Others will correct me if I'm wrong......
DerekB.
Mine ride height had never been adjusted before so I had to take the rod out, factory loctite was too tight.  Once it was out though, no problem.
-     '05 S2R - Carbon Arrow, Open Box and Chopped.     -
Ivan
I had no problem adjusting mine for the first time, without removing the tie rod.  The lock nuts were tight, but not stupid tight.  Just make sure that you have a good pair of open-end wrenches on hand.
Sold: 2007 S2R1000 for canyon carving and commuting - DP ECU, PCIII, BMC air filter with open box, Zard full exhaust, Race-tech fork internals, Ohlins steering damper, and a Penske 8987 triple clicker
2000 996XU (extra ugly) for track days - BST carbon wheels, Ohlins shock, reworked fork, FBF exhaust, and a bunch of megacycle rocker arms. The rest of it is junk - Hey, I'm just happy that it runs...
Sold: 2002 Aprilia RST1000 for touring - De-restricted airbox, Taylormade Racing exhaust
uclabiker06
To just adjust it you don't need to take it out.  If you are increasing the height be very careful because if it is adjusted past a certain length the ends will come out of the rod.  In other words there has to be a certain amount of threads that remain in the rod.  If you are lowering this is not an issue.  Look at the ends of the rod and see if there are any threads by the lock nuts at the ends of the rod.  If there are none then you cant adjust it any lower unless you install a different rod that allows for lower settings.  Good luck.
2006 S2R
2009 Smart
mmakay
Does anybody know the stock rod length of the various Monster models?  620/695?  750/900?  S*R?
- Mickey
LA
I had to take my adj. rod off to do mine. It's not so bad though. Just make sure you have good baseline measurements so you can reliably gauge how much lift you have made. I put mine up one inch.  I think the max listed in the manual is to leave five threads showing.
With a pit bull holding the rear, I used a car floor jack under the sump to hold the bike while doing the work, but I was careful to put a lot of soft material under the sump. Jesus I'd hate to crack the sump - can you say suicide!
Good luck,
LA
hypurone
I did mine in the bike. Just remember that one end is left-hand threads!! It should be the end with the notches in the nit and collar... and yes they were MF'in tight!  >:( But between a really good wrench and a flare nut wrench and a crow's foot I got her done.  [thumbsup] Raised mine 3/4 of an inch, sweetness.
